Power Steering leak
Old 02-22-2011, 04:16 PM
johninar
johninar's Avatar
Default Power Steering leak
I'm having my power steering pump replaced, due to seal leaking.
Do many of you run a different cooler? underdrive pulley?
What's the best answer to prevent this from happening?
I had the rack replaced twice on my 50th.
Wife asked how come such an expensive car leaks so much?
Old 02-22-2011, 04:27 PM
travisnd
travisnd's Avatar
I have an ATI Superdamper which is 10% underdriven, Redline PS fluid, and the OEM C5 Z06/Z-51 cooler. I've never fully drained/flushed it, but periodically suck out the reservoir with a turkey baster and re-fill. I figure it'll eventually do the job.
Old 02-22-2011, 04:36 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
I have a huge cooler, and under-drive pulley works great. Tell your wife you took a street car and abuse and ran it like a race car!
Old 02-22-2011, 07:55 PM
WNeal
Support Corvetteforum!
WNeal's Avatar
Cruise-In Veteran VII
Cruise-In Veteran VIII
"Slower Azz Dog"
St. Jude Donor '06-'07-'08-'09
Getting ready to put the 3rd PS pump in my car.
This time it will get a 25 % underdrive pulley as well
Old 02-22-2011, 07:58 PM
johninar
johninar's Avatar
So this begs the question? 10% 25%??
I drive my car on the street a lot. If it's not snowing I drive it to work.
So what pully should I go with?
Thanks for the responses
Old 02-22-2011, 08:05 PM
Z11409
Z11409's Avatar
http://www.turnone-steering.com/
Old 02-22-2011, 10:47 PM
travisnd
travisnd's Avatar
For the longest time ATI wouldn't make a 25% underdrive pulley because they couldn't achieve their high level of dampening. They finally gave into market pressure and made one. I think the 25% underdriven balancers are too small an you give up some harmonics dampening ability.
If/when my pump eventually goes south I will be getting a Turn One rebuild.
Old 02-22-2011, 11:24 PM
kmagvette
kmagvette's Avatar
Originally Posted by Z11409
If it is a track car be sure to tell them you want less assist. Be insistent and let them know you don't care that you might lose some assist when cranking the wheel hard in parking situations. Going to less assist means less wasted fluid pumped at high RPM. he net result is cooler fluid. I think their track pump moves 25% less fluid. I also had them rebuild my rack. All the work was top notch.
For what it is worth, I have never noticed the loss of assist...but I don't crank the wheel fast when I am barely moving anyway.
Old 02-23-2011, 07:34 AM
jwt1603
jwt1603's Avatar
I replaced a couple of pumps then went to the Turn One unit. No problems in three years.
Old 02-23-2011, 01:28 PM
rustyguns
rustyguns's Avatar
i run hot!!!!!! engine oil hits 290 on the track and have no power steering cooler. i had a small leak in the rack and put in redline and lucas oil 50/50.
leak stopped and rack has been fantastic for 8 months driving to work and 8 track days
its all in the fluids baby
Old 02-23-2011, 01:43 PM
CHJ In Virginia
CHJ In Virginia's Avatar
Had the stock pump self destruct and turn the fluid to brown goo. It was leaking from the front seal and made a huge mess under the hood. Replaced with Turn One track spec pump, Joe Gibbs synthetic fluid and flushed the entire system. Runs great. Spend the few extra bucks and get something that will not self destruct under track usage.
Old 02-23-2011, 10:49 PM
johninar
johninar's Avatar
Thanks for the replies, I ordered a Turn-one pump and 25% under drive pulley today.
Still researching a different cooler.
Also thinking of cam, pushrods, and springs.
Where does all this end?
Old 02-23-2011, 11:25 PM
trackboss
trackboss's Avatar
I use the cooler below on my own FRC as well as a couple race cars with success. Ultra light, cheap, works well, and comes in many configurations. I mounted mine in the "roof" of the radiator shroud and plumbed all with AN fittings.
http://www.summitracing.com/search/I...me+rail+cooler
I've also used the fluidyne power steering cooler:
http://www.fluidyne.com/pl_soc.html
but it does not lend itself to packaging as well as the other one. It does offer less restriction, but that has never been an issue.
To Power Steering leak
Quick Reply: Power Steering leak
