Drag radials on the front for AutoX?
Anyone ever tried it? I have two seasoned Nitto DR's that are now the proper size for the front of my C6 Z06, should I try them on the AutoX? Road course?, No way? They should be ok, just soft sidewalls, maybe run the pressures a little higher than normal hot AutoX pressures? I dont really care if they get torn up and any use I get out of them is a plus.
Matt
Matt
Former Vendor
I think the car is going to have some strange handling with DRs on the front and different tires on the back. I once autocrossed my 86 with worn R888s on the front and new ones on the back and it understeered real bad.
Received 1,754 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I think it will be a disaster. Youre better off on street tires. The DR construction is made with a soft sidewall for launching the car. It will have adverse effects to an autox car.
Most of your comments are pretty much what I was thinking but did you see the big like 74 GM A body the Hot Rod built as an AutoX car? They ran four DR's on it and it worked ok. I might have the put on for now just to see whats its like until my new tires get here.
Thanks for your posts.
Matt
Matt
Heck, it's an experiment, what have you got to lose? Not knowing what you've got on the back end makes it a total crapshoot from our perspective, but still, try it!
I can't tell you how many times I've been lectured on the impending disaster of running 275s up front and 305s and 315s rear on my wagon wheels.
Never had any problems.
I agree with your premise of running more pressure than normal, just use the old chalk method to keep the sidewalls from grinding away.
Let us know how things work out!
Mike
Mike
Well, we once purchased a very nice roadrace car from an individual, and it came with three sets of wheels: two sets had Hoosier R3S03s and 04s mounted on them, and the third set had Hoosier stock car dirt track tires. Now VERY curious, I inquired as to why. The former owner said, almost bursting with pride, "Those are for the rain."
Ed LoPresti
Ed LoPresti
Ed LoPresti
Ed LoPresti
Drag Radials on the front of a solo car could be bad. What if you blew a bead and killed a rim?
- Andy
Are we to understand that a Hoosier oval dirt track tire was
[1] "designed for roadracing", AND it
[2] has "been replaced by the 'road racing wet' and 'radial wet' "?
Does Hoosier know about this? I am certain we would all like to hear more.
Ed
The constuction went from a non-DOT to a DOT late in the life of the Dirt Stocker. When it was discontinued, the Radial Wet and Road Racing Wet were introduced.
They were indeed listed under the 'road racing' section of the Hoosier site. It's weird nomenclature for sure.
Unfortunatly, they were only available late in their life in smaller sizes whil ethey were being phased out as the Wets ramped up and are now totally unavailable now that the DOT and non-DOT are available.
Nitto DR's are designed for combo street/drag use. I'm pretty sure you won't have any disasters on the auto-x course, although they won't be the best tire for that application. I used to have DR's on my gto for street use and never had a problem taking sharp turns in a 3800 lb car. What size are the wheels/tires? The less sidewall the better and like you said, keep the pressures up a little. Just think, you'll be able to stop on a dime .
