Full-face helmets for eyeglass wearers
Old 02-26-2011, 12:14 PM
c4cruiser
c4cruiser's Avatar
Default Full-face helmets for eyeglass wearers
Going to consider a full-face helmet this year from years of wearing an open face (my old Bell Mag 4) and it will have to be something that will accommodate eyeglasses. I have to wear prescription glasses and also have prescription sunglasses.
Looking at SA2010 helmets like the Bell Sport, Bell M4 or Pyrotech Pro Airflow Full Face. Any ideas/recommendations? I do mostly autocross event but also a few track days each year.
Old 02-26-2011, 12:30 PM
CHJ In Virginia
CHJ In Virginia's Avatar
I have used the Bell M4 for several years. It is very comfortable and the eye opening is wide and tall enough to wear glasses comfortably. You have to put on the helmet and then the glasses.
Old 02-26-2011, 12:31 PM
kmagvette
kmagvette's Avatar
Simpson Sidewinder here...no problems at all with glasses.
Old 02-26-2011, 12:43 PM
Last C5
Last C5's Avatar
I use the Bell M4Pro, it's lighter and works very well with my glasses.
Old 02-26-2011, 12:49 PM
PaConehead
PaConehead's Avatar
I use a full face G-Force - ProForce I believe - and I'm pretty satisfied with it. I also wear Rx glasses and was interested in a fairly wide field of vision. I use a tinted shield since my Transitions lenses don't work in the car. I just picked up a Rx sunglasses, so I try those w/a clear shield. The inner helmet pads are designed to accomodate the eyeglass stems, to some degree. Some of the higher end helmets you are considering may be lighter - which is a definite advantage.
Find a full face that fits properly and you can't go wrong!
Old 02-26-2011, 01:40 PM
gkmccready
gkmccready's Avatar
I have a Bell motorcycle & and Bell SA helmet that I wear glasses in. Neither are the wide eyeport models.
Old 02-26-2011, 01:57 PM
TheKomoman
Support Corvetteforum!
TheKomoman's Avatar
St Jude Donor '13
My fiance and I both wear HJC AR-10 full face helmets with glasses and no problems.
Old 02-26-2011, 03:03 PM
WNeal
WNeal's Avatar
Cruise-In Veteran VII
Cruise-In Veteran VIII
"Slower Azz Dog"
St. Jude Donor '06-'07-'08-'09
I have a G-Force full face and routinely wear sunglasses with it, no problems at all
Old 02-26-2011, 04:34 PM
AU N EGL
AU N EGL's Avatar
Get a smoke shield any only wear your normal glasses, not your prescription sun glasses.
Old 02-26-2011, 05:22 PM
c4cruiser
c4cruiser's Avatar
Looks like Pyrotect has 6 different faceshield tints available, clear, light smoke, dark smoke, blue, amber and a chrome reflective shield.
Because my sunglasses have a different frame design and the lenses are smaller, going with a tinted shield makes a lot of sense.
Old 02-26-2011, 05:32 PM
Omaha02Z06
Omaha02Z06's Avatar
Mine is a RCI helmet and I’ve been pretty happy with it over the years. I don’t wear prescription glasses but it accommodates my sun glasses just fine. I believe they offer tinted shields as well.
Old 02-26-2011, 06:02 PM
WNeal
WNeal's Avatar
"Slower Azz Dog"
One thing I did find with mine is that I lose the polarization affect of my sunglasses when I put the shield down.
I have now gotten a smoked and silvered shield and most times don't wear my sunglasses anymore.
I wish somebody would come up with a polarized shield for the helmets.
Old 02-26-2011, 06:40 PM
40YRW8
40YRW8's Avatar
I looked quite a while for a helmet like what you want and settled on the Simpson Voyager. Good helmet, plenty of room for my sunglasses which are wider than my prescription glasses and the wide eye port gives really good peripheral vision.
Gary
Old 02-27-2011, 07:54 AM
Bills Z06
Bills Z06's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Bell Sport for a few years. As a previous poster said, your have to put the helmet on first, then the glasses. Sometimes it's a bit of a PIA!
Old 02-27-2011, 09:26 AM
ErnieN85
ErnieN85's Avatar
I just replaced a Biefe with an HJC Ar-10 I usually put the helmet on about half way then my glasses then pull it down. both work fine.
now a question any body using tear offs? how much of beating does your visor actually take? would tearoffs be a good or bad idea?
Old 02-27-2011, 09:42 AM
drivinhard
drivinhard's Avatar
Bell M4 has a big eye port
Old 02-27-2011, 09:45 AM
Bill32
Bill32's Avatar
+1 on the bell M4Pro.
A couple years ago Transitions came out with "Drivewear" lenses, they are sunglasses and don't go clear. But they change colors for different light conditions and work behind windshields.
I've used them 2+ years and love them. They work fine with my helmit shield.
http://www.drivewearlens.com/home.php?flashchange=8
To Full-face helmets for eyeglass wearers
Quick Reply: Full-face helmets for eyeglass wearers
