Does anyone have some weights on c5 2 piece rotors?
I would consider some over the one piece (usually Brembo) blanks to save some weight (stock sliding calipers) but for the money I would like to know the weights first vs. one piece.
This is for autox primarily so the rotor life & temps are really secondary to the weight.
Thanks if you have any info.
Are they thinner & do you need to replace the stock pots with longer ones or thicker pads?
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Been doing that for years.
most of the C5 front 2 pc are ~2 lbs lighter, the real weights savings it on the rear if you got to a 2 pc without an E-brake drum, they are ~5 lb lighter than stock.
I can't answer your specific question on what fits your car (I selected my rotors out of the Wilwood catalog), but instead of thicker pads or different pistons I'd consider just putting some heat insulating shims behind the pads. Gets the pistons back where you want them (if needed) and also keeps the fluid a bit cooler.
Where can I buy shims? Do they come in thicknesses?
I have Performance AFX rotors. The fronts are 2.5lbs. lighter each then Centric rotors. The rears with e-brake are 3.5 lighter each then Centric rotors. Total savings 12 lbs.
http://shop.performanceafx.com/
Steve A.
Steve A.
in addition to the rotor being 5 lb lighter, you can dump the 3 lb worth of e-brake hardware. 8 lb/side for free, is hard to ignore
Former Vendor
Our 2 piece front rotors for the C5 weigh just under 16lbs. The rears with parking brake weigh 10.12 pounds, without parking brake they are 9.75 pounds. They are all a direct bolt in replacement and are 100% made in the USA. Give us a call if interested or have any further questions.
Robert Finlayson
Performance AFX Motorsports
815-254-2631
Robert Finlayson
815-254-2631
Robert Finlayson
815-254-2631
Robert Finlayson
815-254-2631
AX I would get a thinner than stock rotor in 2 pc to get the lightest.
that's probably a 14" stoptech. IIRC, when I was weighing the 14" stoptech stuff in my shop, the 14" 2 pc rotor was ~/- what the OEM C5 pieces were, about 18 lb or so
What is the life on these rotars? # of track days and at what tracks?
Steve A.
Steve A.
I've seen different material shims sold by a couple suppliers, but I've always just cut my own out of stainless steel using my plasma cutter. It's a lot cheaper, and I can get the thickness (or thicknesses) I want. Sorry I don't have more info than that.
Hard to ever compare or get a feel on rotor life by minutes on track and what track unless you know the driver. Rotor could last one person all season and someone else can kill same rotor in 25% of the time with more abuse. If I knew a person who runs similar times as me on a track then I would feel I would have some idea.
