Prodigy Brake Controller Question
Took the tow vehicle out of winter storage but when I started up the truck the Prodigy brake controller shows a 1.2 on the readout without the trailer being hooked up. Usually nothing but one or two dots are displayed. When I turn the adjuster down I can get the readout to 0.0 but never no readout
When I step on the brake, while standing still, the readout increases proportional to my brake pressure.
When I hook up the trailer I usually get the "c" readout (connected), but now the 1.2 readout remains with no "c". The trailer lights and brake lights function properly when connected. I can't seem to get the "c" to appear.
Is the unit shot? The wires seem fine under the dash. Am I doing something wrong? The unit is about 4-5 years old and I've never had a single problem with it.
Received 8,918 Likes
Did you check the wires where they go into the unit? I have had a couple of controllers that had the wires pull loose. One of them was several years old and the company warrantied it due to a manufacturing defect.
Bill
Bill
I disconnected the unit, let it sit for a moment, and then rebooted it by plugging it back in. Now everything seems to be fine. I get the "n.c." (not connected) and then " . . " reading as it's suppose to do. And when I connect it I get the " .c. " (connected) signal. When I step on the brake with it connected I get the " 1.0" reading showing it's working.
All seems well. I just wanted to report this for future searches....
I thought I had a problem with my brake controller also. I called their 800 number help line. I was absolutely amazed at the knowledge that the guy had about their product.
Turns out the adaptor I had to change from the large plug to the smaller plug on my trailer needed a wire switched.
Point being don't be afraid to call their 800 help line, they were great!
