IMPORTANT FACTS - All About Oil
Gentlemen,
I have copied a very informative article about oil, its processing, its importance to our engines, and the choices we have.
It was written by a motorcycle rider, but strongly relates the our engines. I have also had to delete three tables that were part of the article. I did this because they would not retain their format when posted here.
The article is long, but if you stick with it, I think most of you will find it informative. It refutes several "facts" that we have been told on this forum by self proclaimed experts.
Why do we need oil?
We put oil in our engines to serve several purposes. First, obviously, oil acts as a lubricant. If your engine is operating correctly, there is almost no metal to metal contact - everything is riding on a thin film of oil. However, oil has several other important jobs to do. Oil circulates throughout your engine, and cools parts that cannot get near a water jacket. For example, it's becoming common in sport bikes to spray oil on the underside of their pistons to cool them. There are no water jackets at all in your transmission. Motorcycle transmissions are oil cooled.
Your piston rings do not do a perfect job of sealing. Some combustion byproducts will slip past the rings into the engine. These can be little particles of carbon. Remember, diamond is carbon that was combined under heat and pressure. These little carbon particles can be quite damaging to your engine. Another job of your oil is to hold these particles in suspension until the oil filter can grab them. Also, if your gasoline has sulfur in it (it does), this sulfur can react with water and oxygen to make sulfuric acid. This is stuff that is seriously bad for your engine. Your oil has special ingredients in it called buffers to neutralize acids. Finally, your engine can get internal build ups of tars, waxes, and other gunk. Your oil has solvents to try to dissolve this stuff and get and keep it clean.
Where Oil Comes From
Most of the bio-mass on earth is single cell plants and microscopic critters in the ocean. When these die, they sink to the bottom. Often they fall into a deep crevasse or trench, where they may become covered up by an underwater landslide. After a couple hundred million years of high pressure and no air, the critters get squished into oil. So, oil isn't really dead dinosaurs, but Sinclair Oil stations just wouldn't be the same with a picture of algae on their sign. Today we like to find this stuff, pump it to the surface, and burn it.
The oil we pump to the surface is a mixture of gasoline, kerosene, light weight lubricating oil, motor oil, gear oil, tars, paraffins, waxes, asphalt, sand, dirt, organic stuff, called aromatics, and the occasional dead cockroach. We call this stuff crude oil, for reasons that I think are now self-explanatory. The oil companies have the singularly smelly job of separating the crude oil into its component parts. A hundred years ago we would just heat the stuff up in a complicated still, and catch stuff that boiled off at different temperatures. Fifty years ago we started processing the crude oil with clay and solvents to do a more precise job. Today, we use very complicated systems where we heat the crude oil to precise temperatures, put it under high pressure, and bubble hydrogen and other stuff through it. The idea of all this is to try to get pure chemicals out of this stuff that we just found laying around in the desert.
Most motor oil has a lot of different chemicals in it with very different properties. The temperature at which the oil will start burning, called the Flash Point, is determined by the chemicals that burn at the lowest temperature. The higher the flash point, the more stable the oil is at high temperatures and the less oil your engine will burn. The Pour Point is the temperature at which the oil stops flowing like a liquid. The lower this number is, the better protected your engine is when it's cold. The thickness of the oil, that is the resistance the oil offers to motion, is called the Viscosity. The viscosity depends on all of the various chemicals in the oil and how they react to each other and to heat. Importantly, as the oil heats up, it thins out, that is the viscosity goes down. The better the oil is at retaining its viscosity at high temperatures, the higher the Viscosity Index. All of these properties depend on all the chemicals in the oil. If you could get only one precise kind of molecule out of the raw oil, you could do a lot better than you can do with a mix.
Refining Oil
The oil product you buy starts as Group I Base Oil. The base oil makes up about 85% of the oil you buy. The base oil can be refined from crude oil, chemically (synthetically) manufactured, or a blended combination. Base oils that are refined from crude oil are colorless and pretty much odorless and are sold to the public as mineral oil. Crude oil is a combination of a lot of different chemicals, ranging from light gasoline types of fuels to waxes and tars. When you heat the crude oil, the gasoline and Diesel oil boil off pretty early. Unfortunately, the mineral oil, paraffin, wax, and tar molecules are all hooked up with each other, and it's not so easy to separate them from each other. Also, the crude oil contains the aforementioned aromatics, which are quite bad in your oil. They are very reactive, and when oxidized they cause all kinds of problems. Refining oil means trying to remove the bad stuff, while leaving the good stuff. The more bad stuff we remove, the better the oil works.
The simplest way to refine oil is to process it with clay, a material a lot like kitty litter. The clay will soak up much of the aromatics, sulfur, and nitrogen compounds. Then, you dilute the oil with solvent like MEK (Methyl-Ethyl-Keytone) and/or Toluene (that's the stuff in model airplane glue that's so popular with teenagers), and freeze the oil. The good stuff will mostly stay liquid, and the waxes will solidify and can then be filtered out. This clay-solvent refining process has been around since about 1930.
Oils refined with the clay-solvent process contain a fair amount of paraffin and wax. These molecules cause several problems in an engine. They sometimes fall out of solution, leading to buildups in your engine that must be cleaned out somehow. Also, as these molecules get hot they thin out quite a bit, much more than mineral oil, so they make the oil's high temperature performance rather poor. Finally, at low temperatures the waxes and paraffins thicken the oil so much that you really couldn't call it a lubricant. If you're curious about this, buy a cheap quart of straight 30 weight oil and put it in your refrigerator or freezer over night. You'll be amazed at how thick it becomes. More than half the motor oil sold in North America in 2004 was made from base oils refined with the clay-solvent process, but I don't think this is the type of oil you want to put into an engine you love. These oils are roughly 85% good stuff (oil) and 15% bad stuff (paraffin and wax). To put this in perspective, think of taking a gallon of really excellent oil, and melting a 12" dinner candle into it.
In 1959, Chevron developed a new method of refining base oils called Hydro-Cracking, where you process the raw oil at high temperatures and pressures with hydrogen and various catalysts. In Hydro-Cracking, many of the paraffin and wax molecules are broken up into mineral oil molecules, which increase the performance of the base oil dramatically. Also, far more of the aromatics, sulfur, and nitrogen compounds are removed from the oil.
Since 1990, Chevron's process has been improved. In 1993, Chevron invented the Hydro-Isomerization process, where wax and paraffin molecules are reshaped into useful lubricants, instead of simply being broken up into smaller molecules. By increasing the severity of the Hydro-Cracking process: increasing the temperature, pressure, and time, to process out more and more of the unwanted wax and paraffin molecules, the oil's low and high temperature performance and resistance to oxidation can be improved to the point where the distinction between mineral oils and synthetics becomes blurred. Chevron now licenses this process, called Iso-DeWaxing. This process of oil refining is becoming more and more popular, and in 2004 it accounted for almost half of all base oils. Iso-DeWaxing not only produces much higher-performance oil, but also allows you to start with lower quality crude oil, making us less dependent on the few countries that happen to pump the purest crude oils.
Group II and Group III Oils
Base oils made with the Iso-DeWaxing process are called Group II, and are significantly more pure and have higher performance than Group I base oils. Chevron Delo 400, Mobil Delvac 1300, and Shell Rotella are made from pure Group II oils. Motor oils made with Group II base oils leave far fewer wax and tar deposits in your engine, and have much low and high temperature performance than Group I oils. The resulting oils are roughly 97% good stuff (oil) and 3% bad stuff (paraffin and wax). We just cut that 12" dinner candle down to about 2½".
The high and low temperature performance of oils is described by the Viscosity Index. The V.I. tells us how much the oil thins out as it gets hot. Oils with higher V.I.s maintain their viscosity better at high temperatures. If the V.I. is 90 to 100, we call it Group II and if it's refined to a V.I. of 110 to 115 we call it Group IIa. In the late 90s, an even more involved process was invented yielding base oils with V.I.s over 120. These base oils are called Group III or unconventional base oils. The higher the V.I., the fewer additives are necessary to achieve the required viscosity. For example, fewer additives are needed to turn Group III base oils into 10W40 than are required for Group II base oils. Group III oils have essentially no paraffin and wax in them, at least as compared to the 12" dinner candle per gallon in Group I oils.
Group III oils have properties approaching or equaling synthetics, so long as the temperature is above about 40°F. Group III based oils are often claimed not to perform as well as synthetics in a couple ways. One, their low temperature performance is not nearly as good. This is based upon a ball bearing test, where they offer lower impact resistance than synthetics. Two, since their flash point is slightly lower, it is claimed that they burn off more easily. However, most modern engines are water-cooled, so it's hard to see how the slightly better flash point of the synthetics ever comes into play. The low temperature performance of the Group III oils can be improved enormously by blending in a relatively small amount of synthetic base stock and other additives.
Since about 2000, it has become possible at moderate extra cost to process Group II and Group III oils so that their performance below 32°F nearly matches the performance of traditional synthetics. Because of this oil companies found they could now produce relatively inexpensive 0W20, 5W20, and 5W30 oils. Car companies were quick to see that such oils would help reduce the fuel consumption of their vehicles by a percent or so, which is important as Detroit finds they are selling more trucks than cars. So, these fuel-efficient oils are quickly becoming the factory recommendation in most cars. It's not at all clear that these new low-viscosity oils lead to the longest engine life. But it is clear that these oils help the car companies meet their Federally mandated fuel economy standards.
In the late 1990s, Castrol started selling oil made from Group III base stock and called it SynTec Full Synthetic. Mobil sued Castrol, asserting that this oil was not synthetic, but simply highly refined petroleum oil, and therefore it was false advertising to call it synthetic. In 1999, Mobil lost their lawsuit. It was decided that the word synthetic was a Marketing term and referred to properties, not to production methods or ingredients. Castrol continues to make SynTec out of Group III base stock, that is highly purified mineral oil with most all of the cockroach bits removed.
Shortly after Mobil lost their lawsuit, most oil companies started reformulating their synthetic oils to use Group III base stocks, instead of PAOs or Diester stocks as their primary component. Most of the synthetic oil you can buy today is actually made of this highly-distilled and purified dino-juice, called Group III oil. Group III base oils cost about half as much as the synthetics. By using a blend of mostly Group III oils and a smaller amount of true synthetics, the oil companies can produce a product that has nearly the same properties as the true synthetics, and nearly the same cost as the Group III oil. The much more expensive traditional synthetics are now available in their pure forms only in more expensive and harder to obtain oils.
There are new chemicals emerging which are made from liquefied natural gas called GTL (Gas-to-Liquid) base oils. These will be called Group III+, and many people think they will become an important part of the oils you buy post-2010. These GTL base oils have natural V.I.s of 140 or more, meaning for most applications they won't require any V.I.I. package at all. Natural gas is primarily made up of only one type of molecule, so the refining is already done for you. Most oil wells throw off a lot of natural gas. In many cases, it's more expensive to transport this gas to a large city than the gas is worth, so it's just burned off. For example, Iran burns off enough natural gas each day to power their entire country, electricity, cars, ships, and airplanes, the whole thing. Well, anyway, natural gas is a chemical looking for a use. All you have to do is chemically attach these molecules to each other to turn them into pure oil stocks.
Semi-Synthetics
Semi-synthetics are oils which are a blend of petroleum oil and no more than 30% synthetic oil. If the manufacturer adds a maximum of 30% synthetic oil and does not change the additive package, they do not have to recertify the oil. These days, since everyone has agreed that Group III base oils are synthetic, I'm not sure semi-synthetic means anything at all. The manufacturers love this stuff. It costs about 15% more to make the oil, and they get to charge about double. I don't recommend semi-synthetics. Save your money and take your kids to McDonalds.
Group IV and Group V - Synthetic Oils
To the best of my knowledge, Delvac-1, AMSOIL, Red Line, and Motul 5100 are the only oils made from pure traditional synthetics.
Synthetic oils were originally designed for the purpose of having very pure base oil with excellent properties. By starting from scratch and building up your oil molecules from little pieces, you can pretty much guarantee that every molecule in the oil is just like every other molecule, and therefore the properties are exactly what you designed in, not compromised by impurities from dead cockroach shells or whatever. Synthetics were thus originally a reaction to the relatively poor refining processes available from about 1930 to about 1990. The original synthetics were designed for the Army Air Force in WW II. They simply could not make their high performance, turbocharged; radial engines stay alive on the available motor oils of the time.
One process for making synthetic base oils is to start with a chemical called an Olefin, and make new molecules by attaching them to each other in long chains, hence "poly." The primary advantage of Poly-Alpha-Olefin PAO base oil is that all the molecules in the base oil are pretty much identical, so it's easy to get the base oil to behave exactly as you like. PAOs are called Group IV base oils.
Until about 2000, these PAO base oils had an enormous advantage over mineral base oils in low temperature performance and in resistance to oxidation, which is critical in keeping the oil from forming acids. However, modern Group III oils can nearly match the performance of PAOs at about half the price. Because of this, PAO based oils are rapidly disappearing. There are new processes being investigated which may significantly cut the cost of producing PAOs, and make them an important component of oil again.
Another type of base oil is made from refined and processed Esters and is called Group V. Esters start life as fatty acids in plants and animals, which are then chemically combined into Esters, Di-Esters, and Poly-Esters. Your vegetarian girlfriend should love that. Group V base stocks are the most expensive of all to produce. However, the Esters are polar molecules and have very significant solvent properties. Ester base oil by itself will do a very decent job of keeping your engine clean. So, people who are serious about making superior oil will usually mix some Group V oils into their base stock. Polyol-Ester (Red Line) oils have by far the best performance in extreme high temperatures.
As you can see in the table above, synthetics offer real advantages when your engine is very cold and when your engine is very hot. The viscosity numbers shown above are at 212°F. At 32°F the PAOs and Di-Esters have about one-third the viscosity of the mineral oils, meaning they pump through your engine three times better. Since about 75% of all the wear on your engine happens in the first five minutes after you start it up, synthetics offer an advantage in significantly reducing engine wear.
Making Multi-Grade Oil
Standard oil, pure base stock, would be a single weight, like 30 weight. This pure oil would have no detergent additives to keep the engine clean. This oil would be relatively thick and difficult to pour at room temperature, and would thin out as the motor heated up. On a very cold day, say 20°F, this oil would thicken to the point where you could not start your motor, and if you did, the oil pump could not pump the oil around to protect your motor. It used to be that to start their Diesel trucks in winter; truckers would add kerosene to their oil to thin it out. Then they had to hope the kerosene would burn off before it did any real damage. Today, synthetic oils that are rated 0W40 flow normally down to -65°F and remove the need for engine block heaters or adding kerosene.
An oil sold as 10W40 is no thicker than 10 weight oil under winter conditions, meaning below freezing. The 40 means it is no thinner than 40 weight oil at 212° Fahrenheit. So, the first number tells us the performance of the oil at or below freezing, and the second number tells us the performance at the temperature of boiling water. The chemicals added to the oil to accomplish this are called Viscosity Index Improvers (V.I.I.).
To make 10W40 oil, the manufacturer would start out with 10 weight oil as the base stock. All by itself, this oil would thin out so much at normal operating temperatures that the oil film would be useless. So, they add these very special very long molecules, the V.I.I.s. The V.I.I. molecules, called Polymeric Thickeners, are as much as 1000 times as long as an oil molecule. The V.I.I. molecules curl up in a little ball at room temperature, but as the temperature gets higher they uncurl and stretch out, like a cat sleeping in the sunlight. The more stretched out the molecule is, the more it impedes the normal flow of the oil, thus raising the effective viscosity. Now, this sounds just a little too good to be true. Well, there are two catches. First, these molecules are not lubricants, so the more of them that you add the less oil you have sitting around lubricating things. Second, these V.I.I. molecules can be broken into pieces by various pressures and forces, like being squeezed through the transmission gears in a motorcycle or the hydraulic valves in a Diesel engine. Every time a V.I.I. molecule gets broken, the oil loses some of its high temperature viscosity. Synthetic oils made from pure PAOs or Di-Esters typically have very few V.I.I.s, so these oils are far less subject to viscosity breakdown due to shearing of the V.I.I. package. As a result, Group IV and Group V synthetics are far more stable.
10W30 oil increases its viscosity at high temperatures by a factor of three, which requires a significant amount of these V.I.I. molecules. 10W40 oil increases its high temperature viscosity by a factor of four, which requires even more even longer molecules. 20W50, which sounds a lot like 10W40, only increases its high temperature viscosity by a factor of two and one-half, so it requires fewer of these molecules than even 10W30. 15W40 also increases its high temperature viscosity by about two and two-thirds, so this oil is also more stable than 10W40.
Most passenger car oils today use inexpensive V.I.I. molecules that break apart relatively easily. Conversely, most Diesel engine oil V.I.I.s are chosen from more expensive chemicals that are more shear stable, since an oil change in a large Diesel is expected to last for 15,000 to 150,000 miles.
One way to judge the V.I.I. content of your oil is to read the V.I., the Viscosity Index, at the manufacturer's web page. The base oils all have similar V.I.s to start with, so generally speaking, the higher the V.I. in the blended oil, the more V.I.I.s are present, and the less suitable the oil is for motorcycle usage. John Evans did just such a survey of Valvoline, Chevron, Exxon, Quaker State, Citgo, and Conoco oils. He found that the 5W30 oils all had V.I.s in the range of 158-162; the 5W20 oils had V.I.s of 148-154; the 10W40 oils had V.I.s of 147 to 150; 10W30 oils had V.I.s of 134 to 139; and 20W50 oils had V.I.s of 120 to 125.
In 1994, Dr. John Woolum tested the viscosity of several 10W40 oils in his motorcycle. He found that all of the petroleum oils had lost highly significant amounts of viscosity within 1,500 miles. Only Mobil-1 held up in his test. I have personally tested Delvac-1 synthetic in my ST1300. It was 5W40 when I installed it and 5W25 when I took it out 9,200 miles later. By 1,500 miles, the petroleum oils Dr. Woolum tested were at 10W25 equivalent. By contrast, Dr. Woolum tested petroleum oil in his Honda Accord. After 3,600 miles, the 10W40 oil was 10W37 equivalent. Motorcycles are indeed significantly harder on their oils than cars. Based on this result and the V.I. numbers above, it would seem that 5W20, 5W30, and 10W40 oils cannot be safely used in motorcycles for more than 1,000 to 1,500 miles.
You might ask, if these viscosity index improvers are so expensive and fragile, why have them? Why not just run straight 30 weight oil? If you live somewhere where the temperature never changes, like Maui, maybe that's a good idea. However, if your engine will ever see temperatures below 60 degrees or above 100 degrees, it's important to have multi-weight oil. Multi-weight oils offer far superior protection during an engine start on a cold morning, and they also offer superior protection if your engine oil ever gets above about 230°F. Of course, some old timers will tell you, "I always ran straight 50 weight oil. Yes, that was the stuff. All these new-fangled fancy oils, forget it. It's just marketing hype! All you need is straight 50 weight." Well, that may have been true when motorcycles were 1,500 cc and made 18hp. Today, you can casually buy an engine that makes 150hp per liter. Things are just a little different.
Viscosity is not actually measured in weights, but rather in units called Stokes. If you're a famous scientist they name a unit after you. Stokes was a guy who worked on fluid flow. For oils, we use 0.01 Stoke, called a centi-Stoke, and abbreviated cSt. Weights are a classification invented by the American Petroleum Institute (API). A different unit of viscosity, the centi-Poise, is used at very low and very high temperatures.
The High Shear Viscosity number is the one that actually correlates with oil film thickness on your bearings at operating temperature. You can see that there are only three choices for oil: Light 20, 30, and 40, or Heavy 40, 50, and 60. The Cranking Viscosities above show you the temperature at which you can start your engine safely. 20W oils are only safe down to about 28°F. 5W Rotella or Mobil-1 SUV oil is safe at -13°F.
Motor Oil Additive Packages
In addition to the base stock oil, oil manufacturers add what's called an additive package. Additive packages are typically not made up by the oil companies, but rather by a few companies that then sell them. Additive packages contain several different chemicals with several different purposes. Here's what the additive package is supposed to do for you:
- One component is detergents and dispersants. These chemicals are designed to hold onto foreign particles and chemicals in your engine, and sometimes break them into smaller pieces. These foreign chemicals may be combustion byproducts, or junk that slipped past your air filter. If the particles are large enough, then they will eventually be grabbed by the oil filter and taken out of circulation.
- Another component is buffers. This is typically calcium, magnesium, or boron. These chemicals are present to neutralize any acids which form in your engine. Acids are bad for your bearings and other important things.
- Your additive package will include solvents to break up deposits of tar and wax. In premium oil, some of the base stock will be Group V Diesters to help the solvent package. Where did the tar and wax come from? Remember, when you opened up your $1.09 quart of Spiffo-Magic SuperLube, you got oil, additives, tar, paraffin, wax, asphalt, ash, aromatics (sounds like perfume when they say that, doesn't it?), and the occasional stray bit of cockroach shell.
- Another component is emergency lubricants. This is typically zinc, phosphorous, and molybdenum. These chemicals are present in case your oil film completely breaks down, due to extreme temperatures or pressures. These chemicals are supposed to be a last resort defense against metal to metal contact in your engine. Oil companies are cutting back on zinc and phosphorous, as these metals are hard on your catalytic converters. They're substituting molybdenum disulfide, which lowers friction and improves gas mileage. It also causes problems for people with wet clutches, which are most motorcycles.
- The Viscosity Index Improvers - Polymeric Thickeners - are part of the additive package. As we learned above, these chemicals are present to make your oil stay thick at high temperatures.
- Finally, corrosion inhibitors. These chemicals are supposed to keep your oil from oxidizing or otherwise breaking down due to time or contamination.
API Oil Standards
The additive package is made to make the finished oil product meet one of the certifications. There are two classes of certification: S, for Service, and C, for Commercial. The certification standards are maintained by the American Petroleum Institute - API. Over the years, API has improved and changed these standards. The most current S standards are SL and SM. These standards differ from earlier standards like SH by lowering phosphorus to improve catalytic converter life, and increasing molybdenum to lower internal engine friction and improve gas mileage. Phosphorus was originally added to oils to help protect high pressure areas like cam lobes and crankshaft bearings, so lowering phosphorus levels is a compromise of lower pollution, perhaps at the expense of engine life. Molybdenum is added to improve fuel economy due to the Federal CAFE standards, thereby helping GM and Ford sell large V8s to the American public, but can perhaps cause problems in engines with wet clutches.
Most S additive packages are also designed to be inexpensive so that the resulting oil can be sold at a low price. SL and SM oils are both low phosphorus; SM oils which are labeled energy conserving are high molybdenum.
About every three years or so, the API releases a new S standard. The new standard supersedes the old standard, so, the SH standard included extra high temperature deposit protection due to the popularity of turbo engines in the early 90s. SJ oils did not have this high temperature protection, as that portion of the standard was dropped. This means that for some cars, oils made to the older rating systems are sometimes better than oils made to the new standards. SH certified oils are probably the best of the S oils for motorcycles and high- performance sports cars, but you can't buy them anymore. Oils labeled as energy conserving are bad for any vehicle with a wet clutch, meaning most motorcycles. Essentially all 0W20, 5W20, 5W30, and 10W30 oils are energy conserving and should not be used in your bike.
Most people blending S type automotive oils are buying their base oils from a company who is most likely using the Chevron Iso-DeWaxing process to make their oils, and then buying their additive package from another company that is highly constrained by the API standards. The cost of getting an API certification for a single S motor oil formulation is from $125,000 to $300,000. The cost for C certification is $275,000 to $500,000. Once testing is complete, the oil can be licensed for $825 per year, plus a small royalty fee per gallon sold for all gallons over one million. The length of time between new specifications is now approximately 2 to 3 years, which does not allow a great deal of time to recover testing costs.
Additive companies, such as Lubrizol, Ethyl, Infinium, and Oronite develop licensed additive formulas that they offer to oil companies to relicense. It is inexpensive to relicense one of these formulas, and the majority of oil companies choose to do this to avoid the costs associated with testing. Thus, the same chemistry is being sold under many brand names. Because of this, S type automotive oils have pretty much turned into a commodity. Although the people selling a particular brand may wish you to believe their oil is superior to any other, in fact if it's got the API seal on it, it's probably about the same as any other similarly rated automotive oil.
Commercial (Diesel) Oil
The additive packages for C (Commercial) certification are designed to promote engine life. The additive packages for C rated oils contain extra buffers and detergents to keep the engine clean and free of acids. C rated oils are far better than S oils at holding and dispersing combustion byproducts and other contaminants, and at not becoming acidic. Traditionally these oils are primarily used in Diesel motors, which are very expensive and are expected to last a million miles or more. When an engine rebuild costs $10,000 - $15,000 and puts you out of work for a week or three, you don't mind paying a bit more for your oil. The C certification tests have been largely developed by Mack, Caterpillar, Detroit, and Cummins to provide the additives necessary to keep these engines running a long time. The latest Commercial oil certification is CI-4 Plus, and includes extra protection for high temperature, high revving motors. Since it's designed for Diesel motors, they don't care about any stinking catalytic thingies, and CAFE is a place where you get a cup of Joe and a donut. CI-4 Plus differs from CI-4 with higher detergent requirements and better sheer stability. The shear stability is exactly what motorcycles need due to running the engine oil through the transmission.
Although C standards are changed every few years, the older standards are enhanced, not superseded. So, newer, higher rated C oils are simply better than older, lower rated oils.
Although few car owners test their oil regularly, most large trucking companies routinely do oil analysis on their Diesel trucks. Used oils are checked for viscosity breakdown, detergent and dispersant function, and metal contamination that would indicate engine wear. C oils that don't measure up are quickly run off the market place. To prevent engine wear, the best strategy is to keep deposits off the pistons, rings, and bearings. Therefore, Diesel oils typically contain half again more detergents, double the dispersants, and a much more expensive and robust V.I.I. package than S type oils. If you go to an auto parts store, convenience store, or grocery store, you'll see that there are dozens of brands of automotive oils, all claiming to be the best. If you look at truck stops, you'll see there are only a very few Diesel oils sold, typically Rotella, Delo, and Delvac. Trucking companies find what works for them and won't switch. They're not interested in saving a dollar a gallon on some unknown oil.
The C certified oils are all also S certified, but not all S certified oils are also C certified. The best C certified oils are SG, usually SH, sometimes SJ. I don't know of C certified oil which is SL. The best S certified oils are CF certified, which is a relatively old and obsolete C standard, and does not include the tests for high speed, high temperature engines that CG, CH, and CI have. In fact, CF oil does not meet the current factory standards for Volkswagen or Mercedes Diesel passenger cars.
The API charges serious money to test oil, and to certify it. If the API really tested the oil in their independent lab, and the oil company pays their royalties on time, the oil company gets to display the API seal on their product. Some smaller companies don't pay the API to test their oils and certify them. In these cases, you won't see the API seal. Instead you'll see some words like - Meets or exceeds all manufacturers’ warranty requirements of API Service SJ, SL, CF. It's up to you to decide if you trust the manufacturer to actually test their oil themselves and tell you the truth about the results.
Racing Oil, NASCAR Oil, etc.
Some manufacturers also sell something they call racing oil. Normally, this is actually fairly decent oil, but you should not be misled into thinking racing cars use the best oils for you. A race car driver starts his engine one time only, warm it up slowly and carefully, and then run the engine near or at the red line for a couple hours. 100 to 500 miles later, they completely tear down the engine and replace all the worn parts, the oil, and the oil filter. If you think you might like to go more than 500 miles between major engine rebuilds, you might consider that your use of your engine is quite different from Michael Andretti's.
Why do we change our oil?
We're now in a position to discuss this. Your oil is a combination of one or more base stocks and a complicated additive package. The base stocks will actually last as long as your motorcycle, many hundreds of thousands of miles, several years. The reason we change our oil is the additive package wears out. The buffers get used up neutralizing acids. The detergents and dispersants get used up clinging to gunk that's too small for your oil filter to pick out. The V.I.I. package gets shredded by high pressure. You could imagine a device that pulled out your oil, gave it a very thorough cleaning, replaced the buffers, detergents, and V.I.I. molecules, and put it back into your engine. This would be like a motor oil dialysis machine. However, in a country that has Texas and Alaska, in a world where oil is $90 a barrel, this makes no sense. So, we dump out our entire four quarts of oil because 3% of the oil is used up. It's really just a cheap way of getting a bunch of contaminants out of our engine.
This is why it does make sense to recycle oil. If you can process hundreds of gallons at a time, you can separate out the base stocks economically. If you use synthetic oils and bring your used oil to a recycling collection point, you can feel especially good. A bunch of school buses and city buses are going to get an extra little kick in their base stock because of you. In fact, you can tell your wife that's why you need this exotic, expensive synthetic oil. It's solely out of your concern for the children. If everybody used Spiffo-Magic SuperLube and recycled their oil, the recycled oil would be junk, and in no time flat the school buses would all break down. The kids would have to walk to school, 23 miles, in the snow, uphill both ways. Why, in no time flat the kids would lose weight, improve their cardiovascular conditioning, and generally be healthy and have more energy. What a nightmare!
Choosing an Oil for Your Motorcycle
There are a few special problem areas for motorcycle oil. Most motorcycles have wet clutches, which means the motor oil runs through the clutch. If the motor oil has too much molybdenum in it, there are fears that the clutch can start slipping. No one I know has ever actually had this happen to them, but the warnings are all over your owners' manual and the oil companies' web pages. On the back of all certified oil cans is a circular stamp with the certification. Avoid oils that say energy conserving in the bottom half of the donut. These oils contain friction modifier additives that could cause clutch slipping over time. Essentially all 0w20, 5W20, 5W30, and 10W30 oils are energy conserving, and should not be used in your motorcycle.
Most motorcycles run the engine oil through the transmission, and the transmission gears are very hard on the oil's V.I.I. package. This means that over a couple thousand miles, the oil's viscosity can break down. Standard car oils are only good for typically 1,500 miles before they've lost about half of their viscosity. Remember, 10W40 oils contain a lot of V.I.I.s, which tend to shear in your transmission, so I believe 10W40 oils should be avoided. You can't use 10W30 because of the friction modifiers. This doesn't leave much. Commercial 15W40 oils are a good choice, because they have relatively few V.I.I.s, which are the more expensive shear-stable sort. Synthetics typically don't contain much of a V.I.I. package, so shear is not as big an issue with them.
Some people use their motorcycles only sporadically. This means the oil can all drain completely into the sump, leaving no protective film on the bearings. The first start after a long period of nonuse can be particularly hard on an engine. Film strength is very important if you're a sporadic rider.
There are several key advantages to using Synthetic Oils:
1. Synthetic oils have a higher viscosity index than mineral base oils. Synthetics have better resistance to thinning at high temperatures and thickening at low temperatures. Since synthetics have little or no V.I.I.s. Synthetics last longer in service, without radical changes in viscosity.
2. Synthetics have higher film strength than petroleum oils, so it takes a lot longer for the oil to drain completely off your bearings and into your sump.
3. Di-Ester synthetics are polar molecules with solvent properties which dissolve residues and combustion byproducts.
Choosing a Break-In Oil for Your Motorcycle or Car
The theory that synthetic oils should not be used during break in is the same as the theory that your engine will break in better if you use synthetic oil, but add a dinner candle to your four quarts of engine oil. Frankly, I find this theory questionable. Corvettes and Porsches come from the factory with Mobil-1 in their engines. Remember, these engineers have designed world-champion engines for F1, Indy, 24 hours of LeMans, etc.
There's a lot of mythology surrounding break-in oil. It's simply not the case that synthetic oils are more slippery than conventional oils. Also, break-in of a modern engine is completely different than break-in of an engine made before about 1980. Modern engines, by comparison to something made in the 60s, are pretty much already broken in from the factory due to the fact that today we hold much tighter machining tolerances.
I recommend you change your break-in oil at 75 to 100 miles. Your engine does shed a fair amount of metal particles in the first 20-50 miles, and I really can't understand why you would want this stuff floating around your bearings for the first 4,000 miles. I recommend you switch to a good synthetic at your first oil change.
Recommendations
I get a lot of e-mail, “My buddy has 283,000 miles on his 87 Yamazuki Nintruder, and he’s never used anything but $ .35 a quart grocery store oil that he changed every 48,000 miles.” Here’s the truth. Modern Japanese engines are amazingly well engineered and can tolerate a surprising amount of abuse. However, putting automotive oils in your motorcycle and running them for more than 1,500 miles is abuse. I abuse my motorcycles enough with the way I ride them, without adding the abuse of cheap oil that will break down in 1,500 miles.
The question of which oil is best is not settled. We know what we want. The oil would be inexpensive, last a long time, and make our engine never break. There are various articles in MCN which do a chemical analysis and make recommendations based on the content of the additive package. I am very skeptical of this, as the utility of these chemicals at various levels is never tested, and the base oils are not tested. There are a couple articles that actually test for viscosity breakdown, and standard petroleum oils don't do very well. Consumer Reports once did a 4,500,000 mile test of oils in NYC taxicabs. However, these engines only start once per day and are water-cooled. So, they mostly avoid cold start-ups and overheating. If you're using a standard automotive petroleum oil in your motorcycle and running it for more than 1,500 miles, you are taking chances. By 1,500 miles, the V.I.I. additives are pretty much broken down, and the oil has therefore thinned out enormously.
Your engine will not explode if you use Spiffo-Magic Superlube for 4,000 miles. Your engine will not explode if you never use synthetic oils. However, any of these choices puts additional strain on your engine. You buy $300 tires for your car that last 45,000 miles, and $150 tires for your bike that last 8,000 miles. Why on earth would you try to save $5 on each oil change to buy oil that can't hold up in a motorcycle engine? My DL650 runs its oil through the transmission. I run off-road with its extreme environment of silicon blow-by at the piston rings. I'm pretty much always revving my engine at 5,500 rpm or more (red line on the Corvette, the one that comes with Mobil-1 as the factory fill). I stress my little engine enough without making it use dinner candles as lubricants. Nor do I wish to make the bearings run in 10W40 oil that's broken down to 10W15 oil. Some people should, in my opinion, clearly use synthetic oil.
You should be using a synthetic if:
- You routinely start your engine in temperatures under 40°F.
- You live somewhere where it gets below -35°F, and you want to start your car. In this case you must use either Mobil-1 0W30, 0W40, or the Canadian 0W40 Rotella.
- You leave your vehicle sit unused for months at a time.
- You are unable or unwilling to change your oil within 2,000 miles.
Now, before you get all excited about the possibilities, you must also keep in mind that the Diesel engines don't run their oil through their transmission, and the large Diesels all have two oil filters, one a normal paper filter, and the second is a 1 or 2 micron filter that catches pretty much everything. We don't have these secondary, ultra-fine oil filters on our bikes or cars. Also, the large Diesel engines hold eleven gallons of oil. An oil and filter change costs these guys $450 if they use synthetics, $180 if they don't.
The synthetic Diesel oils are 5W40 oils. Some people have expressed concern to me that this doesn't match the 10W40 specification for their engine. The 5W rating only applies when the oil is cold, below about 80°F. Once your oil and engine are up to operating temperature, these are 40 weight oils, just like all the others. In cold conditions, under 40°F, the 5W oils are much better for your engine than 10W oil.
AMSOIL, Motul 5100, Mobil-1 MX4T, Mobil-1, Red Line, and Golden Spectro are apparently made with high quality additive packages, similar to the commercial synthetics. Personally, I would find it reassuring if these oils were CI-4 certified. However, many motorcyclists have used these oils for years with good results. They are all fine oils, and perfectly acceptable to run in your motorcycle. They are a bit on the pricey side. Delvac-1, AMSOIL, Red Line, and Motul synthetics contain no petroleum oils - they're pure synthetic. To the best of my knowledge, all other synthetic oils contain some amount of Group III oil. Mobil-1 automotive oils also contain small amounts of moly - about 100 to 200 ppm. This can cause clutch slippage in some motorcycles. I've only heard of this being a problem in Honda Shadows.
I'm sometimes asked if it's ok to blend your own oils. Yes, it is. Oils are all made out of pretty much the same chemicals, and nothing really bad will happen. If I wanted to blend my own oil, I expect I would use something like 25% Motul 5100 10W40 and 75% Chevron Delo 15W40, which would get me both the advantages of a lot of Di-Ester stock (5100 is pure Di-Ester) and the Diesel additive package. In the winter, however, I would use 25% Motul and 75% Rotella synthetic, to get the superior low temperature performance. In fact, I just run Rotella synthetic in everything I own, year round: ST1300, DL650, Superhawk, Chevy Silverado, and my motorhome.
I'm also sometimes asked if it's ok to run non-Harley oils in Harley-Davidsons. Yes, in my opinion. If you change your engine oil every 3,000 miles or so, you can run pretty much any decent oil. I ran Valvoline in my Harleys for 120,000 miles. For extended oil life or superior protection, I recommend AMSOIL, Golden Spectro, Motul 5100, or Mobil-1. Harley recommends 20W50 oil, so Rotella or other synthetic Diesel oils will not do. However, the 15W40 Diesel oils meet the same film strength standard as 20W50 oil, and are just fine to run in your Harley. I'm told that the standard Harley oils are made by Sunoco, and the Syn-3 is made by Castrol. The Syn-3 Harley synthetic is primarily Group III oil, and contains very little PAO or Di-Ester stock. I don't consider the Syn-3 Harley oil particularly excellent oil, nor competitively priced oil.
If you prefer less expensive petroleum oil, Chevron Delo 400, Mobil Delvac 1300, and Shell Rotella T are available at any auto parts store for under $30 per gallon, or at Sam's Club and Costco for under $25 per gallon. This price is reasonably competitive with passenger car oils, and you are getting Group II oil with the superior commercial additive packages. Notice in the table above that these oils have particularly good high shear film strength, meaning the protection you get for your bearings is much better than with 10W30 or 10W40 oil. I don't have any information about how long you can run these oils before their viscosity breaks down, but I'm confident it's at least as long as the best consumer petroleum oil. If you're really into saving money, you can often find these oils locally in 10-gallon drums for about $150. This should keep your bike, your car, and your wife's car in good shape for at least a year. Farmers, ranchers, and truckers buy these oils in large quantities, and we get to ride piggy back on their economies of scale.
* You routinely start your engine in temperatures under 40°F.
* You live somewhere where it gets below -35°F, and you want to start your car. In this case you must use either Mobil-1 0W30, 0W40, or the Canadian 0W40 Rotella.
* You leave your vehicle sit unused for months at a time.
* You are unable or unwilling to change your oil within 2,000 miles.
I totally disagree with that statement due to oil testing and talking to labs like Blackstone. I have been running non-synthetic for years and get 12,000 mile change intervals not 2,000. Even test in my track car the oil is good for over 2,000 all track miles. They actually told me 4,000 would be safe with 10W30 Mobil 1. Not saying all cars here are cooled like mine but testing tells your tale for your car. 15W40 is rated for use below 40*F in diesel engines.
Nice article thanks!
St. Jude Donor '10
It is important to understand the differences between a synthetic and a nonsynthetic oil, and I didn't have to read the entire thing to tell that this guy is not completely educated on the subject.
Synthetic oils do not lubricate as well as a non-synthetic group III base stock because they are made up of longer molecular chains. These chains contain more molecules and molecular bonds to one another and are more difficult to shear, and do not provide as great of lubricity as a shorter chained non-synthetic as they provide a greater amount of friction for the same viscosity.
Operating time does not break down oil. Temperature does. The application for a synthetic oil is when the operating temperatures are too high for a non-synthetic oil to maintain its molecular geometry and shears its intermolecular bonds, ie 'breaking down' and losing viscosity.
The other issue you run into on long oil change intervals in an internal combustion engine is the addition of other molecules into the oil from combustion, such as gasoline (a solvent) slipping by the rings into the base. No oil can change this, but depending on an engine it may be a very long time before this proves to be any sort of issue.
As the previous poster said, a high quality group II such as Mobil 1 (yes, you read that correctly.....) is hard to beat, while a group III will provide the lowest friction and most power. To back the science, I, along with many colleagues, have seen this time and time again from laboratory tests on oil samples.
Blackstone Labs told me they see no difference in engine life from synthetic to non synthetic when proper oil maintenance is followed. My Ford Excusion diesel gets oil changed at 5,000 miles due to fuel contamination and my Dodge diesel gets it at 12,000. Both are slated by manuals to get oil changes at 7500.
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
A mobil 1 rep gave a talk at one of the track events that I attended and stated that all mobil 1 oils have the ZDDP cut back considerably for catalytic converter life except Mobil 1 15-50. For track use, it is Mobil 1 15-50 for me. Amsoil for my duramax.
Good article!
Good article!
google or blackstonelabs.com I think. They will send you a kit for free.
http://www.blackstone-labs.com/
Good article!
Good article!
Now, automotive use, I'm right there with you.
BTW, Pumba, thanks for sharing!
Have a good one,
Mike
Premium Supporting Vendor
Did they stop making that - not listed on their website. Only 50 grade I could find is the normal Mobil 1 15w50.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
It has been interesting to read your comments.
When I posted the article I did so because I found bits of information that I had not been previously aware of.
I would ask John what the viscosity of his oils in his three vehicles are when the oil is new, versus when he drains the oil? Has the viscosity been lowered by shear?
How many of us are using oils with 100% Polyol Ester base stock?
How many of us are using a Group II or Group III base stock oil with a small amount of PAOs or Di-Esters added to it, and it's labeled SYNTHETIC?
I have a Corvette friend who also owns a turbocharged Chevy HHR. Blackstone's analysis told him that his Mobil 1 5W30 oil's viscosity was significantly reduced by 4,000 miles of street driving. And, by 24,000 miles the analysis started to show high iron content.
Pumba,
I've used Blackstone labs for several of my cars for many years now. I've used easily-available full synthetic 10w-30 in all applications, starting out with M1 and now using Quaker State.
One thing I've *not* used is synthetic "blends", because there's no way of knowing what ratio that "blend" is.
In any case, running the vette (223,xxx miles) down to 10% on the Oil Life Monitor, and running my '94 Z-28 (230,xxx) and '03 Crown Vic (165,xxx) to 10K miles each, none have had any viscosity issues, nor have the additive packages been depleted. Blackstone states that the wear rates are always lower than normal for the mileage I have on the oil sample.
My point is, for our engines, I've not found any measurable differences between which full synthetic oil to use. Are there better oils to use? Define "better". Better properties? How long an oil interval do you want? Better value? Better "feel"?
No flaming, I really enjoyed the article; it was well written and balanced, IMO. Thanks again for sharing.
Have a good one,
Mike
Have a good one,
Mike
Pumba,
Have a good one,
Mike
Have a good one,
Mike
Feel is everything! I never changed the oil on anything and didn't thing it ran better after it!
I think what is most important about oil is that you make sure enough of it gets to your motor under high RPM and high lateral G's.
Motorcycles don't have this issue, but our cars do.
I just changed the oil in my Z06....11 quarts (yes 11 quarts..cha ching). No cheap way around that oil change!!!
Pumba,
Have a good one,
Mike
Have a good one,
Mike
Mike,
Thanks.
JR
how often do you change it, and what are you running?
