March & April 2011 Towhooks, Delrin Suspenion Bushings
Supporting Vendor
Good morning Everyone.
march just passed the halfway point and warmer weather is returning to the! If anyone wants to get started on 2011 car prep, maintenenace or just needs some parts, don't hesitate to call or email...
Below is the updated list for setup work, tow Hooks, Delrin suspension bushings and some other items...
Call 610-482-0141 if you have any questions or to order with CC info. I try to answer all the calls myself, but if I am on the phone, you will get my voice mail. Just leave a message and I will call back as soon as I can.
If you would like pictures of any of the items below, send an email to jfaphoenix32@aol.com and I will email.
We also have pictures on www.phoenixperformance.net under parts and cars for sale.
Thank you for your business and support. We appreciate the kind words of all of our friends and customers.. If you ever want to discuss Corvettes, both T1 and track day issues, don't hesitate to call. If you want to do something more advanced, like a World Challenge car, just call me.
Prices below already refect 10% discount off of our normal prices.
Joe
1. C5 Tow Hooks Hinged front and rear...... $145 Per Set, Frt and rear.
2. C6 Tow hooks, non hinged rear only. $145
3. C6 Z06, C6 Z51 and base model, Removable front Tow eye and non hinged Rear Tow hook set $265
4. Roll cages for C5 and C6 Corvettes, Z51, Z06 and ZR1, call for info. All of our cages are custom built to your specs.
5. C6 and C5 Corvette Track Day Set up and Other maintenance. Call for Information. 610-482-0141. We will customize the setup to your specs or we will use our own.
6. Engine rebuild service. Complete balance and blueprinting, machine shop, cam and head upgrdes and performance improvements.
7. C5 and C6 engine tuning by appointment.
8. Supercharger and turbo Installs. Authorized Hennessey Performance Installer.. Call for quotes and specific specs.
9. Complete Set of Delrin suspension bushings. For all control arms
Get rid of the rubber bushings that push out for good!!! $1195 per set for the bushings, plus install. (send us your control arms) and shipping...
Joe
Supporting Vendor
we sell them as fast as we make them.. I will get some pictures up
call me if you need some. Send email and i will send pictures.
Supporting Vendor
Don"t know why they say that... we custom machine each set so that they fit the control arm variances...
You need to send us your control arms and we will insatll them
How do you deal with the angular deflection at the lower arms when you adjust camber (or caster in the front)? Or said another way: the front bushing on the arm and the rear are not always coaxial, and delrin doesn't like to deflect like rubber or even poly will.
Joe: I emailed you about buying just the front tow hook base. It should work with a standard large eye-bolt right? We have TONs of 'em laying around at work.
Hmmm, same question as Mgarfias.
I would have hoped for a more technical response than "It's in the instructions".
If it's proprietary, in the design, then just say that.
I have also seen it discussed in a few places that the solids can cause problems at the ends of adjustment.
Supporting Vendor
sorry.. that was a quick answer...
We mill the bushings at the end to reduce interference, then we adjust alignement to make sure fit is correct.
The delrin does flex slightly to help solve the issue also.
So far, no problems on our test cars..
Joe
Joe
No experience with these bushings but my business is machining plastics so I can tell you with some experience that while being harder than urethane, Delrin is not a rock-hard material. It will flex and give a little bit, which is among the reasons it's used for shift *****. It is a very nice material to work with as well, machines very easily, holds tolerance well and produces a great finish.
If you take out the eccentrics and use a fixed block you can set the alignment once, bore the hole in the delrin and it won't change.
From then on all alignment will need to be done with the upper arms in the front and the rear will be fixed except for toe.
Front and Rear, lowers only.
Ok, that makes a lot more sense. I was thinking that they'd setup some way to make the deflection happen in the bushing sorta like what Hoffman did with his shock mounts.
In the front lowers on my car I've got the arm setup square with the same size camber plates front to back, then adjust up top. One of these days I'll get my lathe spinning and cut some delrin for the lower fronts and the upper rears. Then if I get really ambitious I'll build a spherical setup for the upper fronts and the lower rears.
