ARE Dry sump install question
Old 03-21-2011, 10:58 PM
Corvee
Corvee's Avatar
Default ARE Dry sump install question
Anyone have any suggestions on installing the breather can on an ARE stage 2 system? Having a heck of a time finding a spot under the hood. Considered putting behind the tank in the fender wheel but was told the breather needs to be higher than the valve covers. Also, considered the firewall by the tank but the hood will not clear the filter on the top of the can. Breather in the middle of the picture below.
Old 03-22-2011, 03:07 AM
C&M Racing
C&M Racing's Avatar
I modified the bracket and mounted it to the tank. I used a senond nut on the top tank bracket and made a bracket from the vent to the firewall.
Old 03-22-2011, 09:36 AM
Corvee
Corvee's Avatar
Thanks for your response. Do you have any pictures?
Jim
To ARE Dry sump install question
Quick Reply: ARE Dry sump install question
