does 06-09 a6 transmission hold up to track use
Old 03-21-2011, 11:33 PM
frankgtb
frankgtb's Avatar
Default does 06-09 a6 transmission hold up to track use
does 06-09 c6 a6 transmission hold up to track use with proper cooler and maintaining fluid temps within limits????
Old 03-22-2011, 03:04 AM
C&M Racing
C&M Racing's Avatar
It is very hard to keep an automatic cool.
Old 03-22-2011, 04:53 AM
morris4608
Cruising
morris4608's Avatar
I have an 07 a6 that is holding up fine, added a cooler and change fluid each year.
Old 03-22-2011, 04:59 AM
frankgtb
frankgtb's Avatar
Originally Posted by morris4608
i have an 07 a6 that is holding up fine, added a cooler and change fluid each year.
yes which cooler do u recommend and iam adding a fluid temp gauge
have you ever circuit tracked your 07 a6?
Old 03-22-2011, 10:14 PM
2000BSME
2000BSME's Avatar
I was very impressed to see a 600+ hp corvette with an a6 at the track maintaining a 200* trans temp after several hot laps. The owner said that it never overheated, but he had changed it out once for failure.
My a4 trans is impossible to keep cool, as I have taken extensive steps to do so. I am buying a manual vette soon for this reason.
To does 06-09 a6 transmission hold up to track use
Quick Reply: does 06-09 a6 transmission hold up to track use
