stock C5 Z06 ride height
I am sending my Z06 in to be aligned. The previous owner lowered it all the way on the bolts. I need to get it back up to stock height and realigned. The shop wanted to know what the stock ride height is measured from the frame at the jack points
thanks
thanks
Good question.... however, lowered to the max on stock bolts is really the ideal setup. That should lower the car around 3/4" over stock.
If your car is really slammed the previous owner probably cut down the bushings on the end of the height adjusters. If that's the case they you will only be able to raise it up so much. The folks who really want a "slammed" car will cut most of the bushing off the front and run a longer bolt in the rear.
Here is a link to the C5 tech forum where it is shown... As well as a pic to where it is measured from along the frame.
http://forums.corvetteforum.com/c5-t...de-height.html
I am a bit surprised, it says that the front should be 6.02 inches and the rear 6.22, that's pretty high, but that is what the manual says.
No it isn't, lowered all the way on stock bolts is lower than you should go for best performance. Most of us have been there, tried that, and it doesn't work... Take your car to Phoenix and it won't come back that low either. Maybe they know something you don't. That subject has pretty much been beaten to death on this board. If you lower it all the way in the back on stock bolts you will be on the bump stops with a serious tire, some cornering load and even a small bump. Even with shorter shocks (that I have) I tired lower ride heights and it wasn't faster. The timer doesn't lie.
The car doesn't get into the bump stops and runs around quite well... Last month at VIR I ran a 2:05.5 in the car which was only 2 thenths off the TTA record until a Subaru driver set a new TTA record with a 2:04.8 in the same session.
YMMV
I lower to the max in the front w/o cutting any of the bushing then lower the rear as far as possible while maintaining forward rake. The car ends up about 3/4" lower than stock.
YMMV
YMMV
YMMV
YMMV
at the min weight a TTA car runs at, it ends up sitting pretty high (statically) when looking at it, especially in the rear. My rear bolts are all the way lowered (pretty much) and it looks like a 4x4 in the back. Danny Popp was making fun of me in Dec
I had to put the LG rear lowering bolt kit out of my old vert in the car to bring the rear down a little more
