rear wing guys....what size you run?
Old 03-24-2011, 04:08 PM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
Default rear wing guys....what size you run?
Kognition told me most guys run a 71", but Id like one that dosnt go past the fenders to much...
Old 03-24-2011, 05:57 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
I don't think 71 is past the fenders and that is probably what I have. The C5 is roughly 6' wide I guess C6 slightly narrower. Wing (ACP) is buried in the garage or I would measure it exactly. i just took a rough measurement to halfway across the car in the tail.
Old 03-25-2011, 11:08 AM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
the old World Challenge sizing was based on the Spec Trans-Am series wing...10" chord, 6' span. 72" is large, but you want it out in the clean air as much as possible.
Old 03-25-2011, 01:05 PM
VGLNTE1
VGLNTE1's Avatar
eh, id rather have it below the roof line. this car is still 95% street car that I just road race on the highway I dont have enough aggresive front areo to get that much wing in the air
Old 03-25-2011, 08:15 PM
John Shiels
I moved mine up to the roof line which was about 3-4 inches above the picture.
To rear wing guys....what size you run?
Quick Reply: rear wing guys....what size you run?
