Why are you selling and if it's because you are changing to a different clutch, why the change?
Gary
This Clutch was only a temp clutch while I was finding a stronger clutch disc for my lighter Spec 2+ clutch (which had started to slip). Once I received my Spec 3 disc, we pulled this back out...
This is a great clutch. Very smooth engagement and can hold allot of power.
Wish I had known you were needing a stage 3 clutch. I have a basically new one.
This was almost 3 years ago...The LS7 has been sitting in my garage since...and I didnt actually need the clutch (I already had that), just needed the disc.
