230mph flip in Corvette at Texas Mile
Old 03-29-2011, 09:55 AM
trapp
trapp's Avatar
Default 230mph flip in Corvette at Texas Mile
Glad no one was hurt!
http://www.autoblog.com/2011/03/28/v...sh-at-230-mph/
Old 03-29-2011, 10:04 AM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
is that Hinson from AL? they are a forum sponsor no?
Old 03-29-2011, 10:12 AM
ben dover
ben dover's Avatar
Location: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Damn.
Old 03-29-2011, 10:23 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
230 is a whole new ball game from 200. Wonder what happen? Mechanical failure or some bad aero? Hope no injuries and the rest is money only.
Old 03-29-2011, 10:36 AM
trapp
trapp's Avatar
I do believe its Hinson motorsports..........very lucky that it did not continue to flip and spin.
Old 03-29-2011, 11:40 AM
Solofast
Solofast's Avatar
That's very true. With the power it takes to drive a stock bodied car to well over 200 hp you have a scenario where you can overdrive the rear wheels and get loose, even in a straight line. Just because you are trying to go straight, doesn't make it easy when you are trying to go that fast. Remember C&D spun and flipped their Camaro at the salt flats the same way. Big power can get you in trouble even on the straights...
Old 03-29-2011, 12:32 PM
John Shiels
I remember the work LPE put in the Firebird to get to try to get to 300 mph in a stock body car. They fell a few miles short of 300. Slightest aero screw up and your gone. Not sure if this was a stock bodied Vette but it may have made enough lift at 230 for that to happen and the slightest bump would really help it upward. Even most exotic limit there cars to a bit over 200 as it is bad to kill your customers.
Old 03-29-2011, 01:05 PM
Wasserott
Wasserott's Avatar
Google search...
Old 03-29-2011, 04:30 PM
John Shiels
Wild wild guess and speculation on my part but it don't look like much rake. Thanks for the picture. Splitter may have contributed with all that taped. It may have changed the shaped a bit. I can't really tell but it seems that way or would a stock car look like that? I would think you need to build speed with testing and feeling few MPH at a time. Someone could just put there foot in it with mega power and be caught off guard with little or no warning.
Old 03-30-2011, 12:37 AM
coffey
coffey's Avatar
Word is they had tire failure at due to contact. Tire grew at speed and touched the car. Really stupid to run those speeds with little to no safety gear.
Old 03-30-2011, 08:26 AM
John Shiels
not sure how much tires can grow although I know they do. Looks like decent clearance in the picture for sure. I guess Hinson will tell the story. 230 no joke because things happen fast. I have been to 190 in my car before the body. 160 to 190 is way different and 200 to 230 is probably much much more of a jump.
Old 03-30-2011, 11:22 AM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
the rear tire blew out...and they were running a MT drag radial...they are not meant for those speeds
Old 03-30-2011, 12:01 PM
froggy47
froggy47's Avatar
What speed is a drag radial good for?
That car got a cage, I can't really see it?
Old 03-30-2011, 12:02 PM
trapp
trapp's Avatar
Old 03-30-2011, 12:38 PM
John Shiels
what is the rating on a MT Drag radial?
Old 03-30-2011, 01:07 PM
froggy47
froggy47's Avatar
I thought they had a tech inspection for that event?
Wonder if snow tires would have been OK?
DR's for a mile run?
Very glad they are ok.
OK, I want to temper my comments a bit, after watching the Hinson post on Youtube, a brave, brash effort for a record, a part failed, need more focus on the suspension/aero/wheel/tire but they already know that.
Big ones on that driver.
Old 03-30-2011, 01:11 PM
sperkins
sperkins's Avatar
Simple 6-point.
http://www.facebook.com/HinsonMotors...sonMotorsports
To 230mph flip in Corvette at Texas Mile
Old 03-30-2011, 02:12 PM
VGLNTE1
VGLNTE1's Avatar
I run the newer MT DRs on my car. and since I am always going uber fast I did some checking. Although they dont come with a speed rating, they told me i wouldnt go much over 180mph with them, and def not for long periods at top speed. 230mph is ludicris to use those tires.
Old 03-30-2011, 02:16 PM
VGLNTE1
VGLNTE1's Avatar
here is the video, and shows the tire
http://www.youtube.com/watch?v=OtsIB...layer_embedded
Old 03-30-2011, 03:26 PM
AU N EGL
AU N EGL's Avatar
Might explain what at slow / stop motion the rear of the car seamed to lift up before the roll
Quick Reply: 230mph flip in Corvette at Texas Mile
