front studs without removing hubs??
know it's been asked before, but can't remember. Will the shorter ARP studs install without removing the front hubs?????
oh, and don't have a stock stud handy, how much spacer will the shorter ARP 2.5" studs allow?? I need at least 1/4"
Thanks!
Thanks!
if you have brake cooling ducts you'll have to remove them (depending on what type you have).
there is a recessed portion of the spindle casting that you can barely fish the stud in from. I have a "tool" I made from a lug nut and a pilot bearing I use with the impact to draw them in, 1 by 1
Quick smack with a hammer or mini-sledge. Do it quick and hard and you won't hurt the hub. When I have hubs off the car I support the flange in my vice but still use the hammer method.
Then to draw them in I clamp the hub in the same vice vertically and use 3 washers and a lug nut threaded on backwards then a big wrench. They pull right in easily (even with the larger ARP splines) w/o having to risk damaging the treads with an impact. It's all about leverage
I've changed OEM studs, I know you can get them out. The shorter ARP's are about the same size, but don't have the unthreaded end. I thought you could do it, but trying to confirm. So 1 yes, a couple "no's".
Still counting!
Still counting!
David yes you can do the oems w/o issue, but even the shortest ARPs are an inch longer than stock. If you've already installed them pop one free with a hammer and see if you can get it out and reprot back
I had ARPs on my old Z06 that didn't have spindle ducts and I couldn't get them out no matter what part of the spindle I lined them up with. Wonder if there's some production variance in the spindles? Plus I couldn't remove my ECS ducts w/o removing the hub first anyway!
The force it takes to beat it out has to be less than the forces they see hitting potholes with 3000lbs of car on top of them. I've never had an issue with it and you really don't have to hit them very hard to make them pop out.
I use the kent-moore tool that chevy specs in the book. Can't remember if its the one for the lower ball joints, or the one spec'd for the studs themselves.
You can easily get the old stud out in the front, but even the shorter ARPs made it a bit difficult to get in so I yanked the hub.
I have the KM balljoint seperator and tried it on one of the studs and it wasn't budging easily.... so I removed it and went back to my hammer method.
But in this case the hub was off the car sitting in my vice.
I can do it with oem but cannot do it with ARP short studs (a smidge too long). But Drivinhard must a made a "lightening cut" on his spindles....
There are just the three ball joints to smack with a hammer to pop loose, hit the hub bolts with an impact, and take the hub to a press. Plus, it's mandatory to remove the hub on the rear where the only extra steps are to remove the axle nut and lower shock bolt.
As an aside, I've removed studs with a big C-clamp using a socket as a standoff on the backside.
To your second question, you'll be gaining nearly 3/4" of thread (as they are fully threaded vs. OEM) on the new studs and can use up to that much spacer.
I still doubt you will see many race teams hammering them out unless it's a pit in & out
I do have the Kent Moore tool for the ball joints I would have to look and see how that works on the studs as mentioned above.
http://www.costplustools.com/Kent-Mo...er_p_9563.html
probably worth the money I didn't see a price listed on a few sites I looked at but I bet it's 50-60 bucks. I think it is more from looking at the other tools. I bought mine a long time ago.
http://www.costplustools.com/Kent-Mo...ol_p_9543.html
I think my tool is like this http://www.costplustools.com/Kent-Mo...ER_p_9496.html
