Tie Rod end options...... bump steer kit??
Going with the ZIP bump steer kit. I have a set of the Energy boots, but am afraid the rod ends are beyond salvage at this point. The BS kit is about the same as 2 moog rod ends, so it seems like a no brainer. I'm not planning on doing a full BS assessment on the car, just set them near stock, although that would be a great project for another day.
I'll post info on the install once they show up.
Pretty much It makes me chuckle that a former World Challenge racer like David is being referred to that thread.
me to on DEI tape!
I know a lot of time was put into the post and some is good but some is really not fact or even good advice. How long has the author been at race cars?
I post my opinions and they may be just as wrong but I don't present them as a biblical. When I post an opinion there are others there also to agree or disagree and then veiwer can decide. I know it says what I have learned but it seems presented as gossple. I may be mistaking it but that is the way I see it and my opinion. If I wrote a book it would have to be fact. Heat and oil don't make dry rot as I see it but it is my opinion.
Did you read the section here on tie rod ends?
http://forums.corvetteforum.com/auto...e-learned.html
That would be great David, maybe start a new thread.
IMO just set the pin height = the stock part unless the customer is lowered a lot.
David can you please post up your thoughts after you've installed this thing. Also: do they use a standard rod end that I can buy from aurora or whomever, or do I have to go to Zip to get replacements.
Clearly you don't know these things yet, I'd just like to know
btw, the rod ends are probably standard sizes, it's the adapter and the tapered end/shims that would be custom. I'll know if a day or two.
#35
Got the ZIP Bump Steer kit in, and I'm initially impressed. For the price of 2 Moog Tie Rod ends, you get a kit with approx 1" of bump steer adjustment, and it uses a standard Arora rod end, so service is cheap ($15 ???)
Anyway, the taper is on the main shaft, and you adjust the shaft in the rod end with 4 shims. Since a full BS adjustment isn't part of this job, I'll just be setting them near stock (unless it visibly would benefit from a minor adjustment). Hopefully at some point I can make track-side adjustments with the car owner and get feed back as well.
#37
Arora VCM-10 Right hand 5/8X5/8-18 Male Rod End w/ Teflon
$12.75 at Irvan-Smith Inc
I'll probably still put a thermal "boot" around the bearing just to be safe, although ZIP tells me they should handle the heat OK.
