Tie Rod end options...... bump steer kit??
#101
I wish my coilover concern would be addressed That's what's holding me back
#102
Platinum Supporting Vendor
Like I said, I don't know about your coil overs. When we made this kit the only coilovers that existed was a set of Penske's. They fit with those. They also fit my custom Afco's I had made but I don't use the Pfadt's so I can't tell you. I have heard they hit, however it depends on several issues such as alignment as well. If you have too much toe in it will bring the rod closer to the shock. You can space it like someone in the post showed and I may come out with the offset one I designed but it is going to be a bit more expensive. The offset clevis will require more machine time since it can't be completely shaped in the lathe.
#105
They clear my LGM coilovers.
More on the subject:
https://www.corvetteforum.com/forums...coilovers.html
C6RAPTOR
#106
Okay this conversation has been good for the most part. I think I am going to go ahead and upgrade our Aurora bearing to the Aurora 3 piece bearing. The static load of the bearing will double so this is a very HD bearing. It also has a liner so you will not get any noise out of it. I am looking into this now, it will make the cost of the kit go up but it will be worth the difference. Thanks everyone who participated.
