Beginner needs advise
Guys,
I just purchased a set of TSW Nurburgring wheels since they are .5 wider than stock I am going to add a set of 305/30/19 & 265/35/18. I am done with the runcraps. I am going to use these for general weekend drives and a couple HPDE one at Walkins Glen at the end of the month and VIR in May then we will see if I am going to continue HPDE. I have done 2 other events and not that great but learning. Hopefully I can get the season out of these tires and if I am going to continue HPDE I will be ready for some dot tires after this. Wheel specifics:
(2) 17x9.0 TSW Nurburgring +50 offset
(2) 18x10.5 TSW Nurburgring +65 offset
Here is the question on tire rack the more reasonable tires that I see are Bridgestone Potenza RE-11 for $1322.00 score 9.0, Continental ExtremeContact DW for $1026.00 score 8.5 and Hankook Ventus V12 evo K110 for $826.00 score 7.9. Here is my thought the Hankook got to be better then the OEM runflats and hate to spend more when they are going to get chewed up at the 1st HPDE I do. The runcrap chucked up after the 1st event and they were finsihed off in the 2nd event.
Does anyone have any track experience with any of these tires and road experience? Thoughts would really like to stay under $1,000 and want the wider wheels.
Guys,
2 years is a rule of thumb. Do 2 years of HPDE and then as the 3rd year is underway, replace. Then you've replaced every 2 1/2 almost 3 years. If you drive the car 8000 mi/yr that's 24000 which is about worn out anyway.
the softer the tire, the better the grip and the less the mileage the tires get.
8,000 miles is far more then what any performance tire can handle. Really can not go on millage, but heat cycles.
Age kills performance tires too. Older tires just do not have as much grip. Older being two years or more
Look at Nittos as well.
Guys,
Stock C5 Z06 wheels are 17x9.5 and 18x10.5.
Ahhh good catch the wheels are (2) 18x9.0 TSW Nurburgring +50 offset
(2) 19x10.5 TSW Nurburgring +65 offset
I but the Hankook on a lot better than factory will report back after Walkin Glen at the end of the month
