Track build using high mileage C5 -- caveats?
All,
I'm considering building or buying a C5 track car starting from a high mileage base -- >100K mi.
I'll replace shocks, bushings, sway bars and will do a stock rebuild of the engine.
What mechanical or structural (?) gotchas should I expect from a car with high mileage which would be absent at 30-50K miles?
Thanks!
Dave
Thanks!
Dave
All,
Thanks!
Dave
Thanks!
Dave
For the engine I installed a fresh LS2 timing chain, LS4 high volume oil pump, and fresh OEM valve springs with new seals. I also threw in some lower mileage rocker arms and fuel injectors I already had in the garage.
Even with a lower mileage motor I'd have still done the timing chain and oil pump upgrade. I don't see the need to do a "stock rebuild" unless the engine fails a leak-down/compression test and is down on power.
These cars were engineered by GM for a 200k mile life-cycle. They shouldn't need any type of rebuilding before that if cared for.
All,
Thanks!
Dave
Thanks!
Dave
It will run great for a while - be prepared to replace torque tube, transmission, diff, and clutch - not in that order most likely.
Received 8,924 Likes
Wheel hubs, tie rod ends, ball joints. Probably would do on a lower mile car but defnitely on a high mile one.
Bill
Bill
Rust! I bought a high mileage Z06 from Wisconsin. Structurally sound, strong motor but found a lot of rust on the suspension components. Find a southern car if you can but not from Varkwso.
Hey you were kind enough to test drive my car and give me honest and accurate feedback before I made the 9 hour drive down
All,
Thanks!
Dave
Thanks!
Dave
If you are going to replace the bushings, shocks, sway bars, and springs anyway who cares how many miles it has?
If you eventually decide you need more power, a higher revving engine, slightly different transmission gears, etc then you still have money left over to put those in later.
Matt
Get a later 2001 or later. Better rod bolts, LS6 block and intake. The later 2001s and on don't have the oil consumption issue (due to ring design) which is magnified on the track. You can add the LS6 valley cover with little drama. Has the better torque tube. Better abs.
I bought a 2001 w/130+k. If you get the bug, you are going to replace all the wear items anyway (like I have), so no use paying extra for them in the first place. If I had to do it again, I'd find a pos and work from there. But, I wanted to drive it instead of wrench on it, so it was worth a little more to me to have something in good running condition.
Most components are cast aluminum but the bolts, fuel and brake lines are not. Aluminum does corrode in a salt environment (looks bad - we all know who that would drive wild!) - Mikes car (the last totalled one) was from Chicago and it showed.
Also if you ever intend to compete with it in TT (NARRA, NASA, SCCA, et. al.) or W2W look at the rules for where you want to run before you start modding/repairing.
I would change the torque tube couplers on a high mileage car and possibly the the torque bearings also. The rest of it depends on the life it had. Just throughly inspect all tie rod ends, bushings, ball joints, etc. Look at the wheel hubs for play and excessive rust. Change all fluids replace the brake hoses. A timing chain and valve springs are a good idea also. I would also recommend an 01 and up.
