C4 2-piece rotors
C4 2-piece rotors
Anyone using them with J55/GS calipers for autocross and/or HPDE?
I have only found Baer and Wilwood. Is one better than the other? Are they worth it? Do they hold up to racing?
I am looking for rotors for my C4, with '96 GS calipers. (no- I cannot upgrade calipers or go to a larger rotor. I race NCCC, so changing those items is a no-no)
thanks-
thanks-
Wilwood stuff is good not sure on the others. Are they worth it depends on your pocket you want to let lose. Doubt they will do a hell of a lot in AX. My Stoptech 2 pc are 1 lb heavier than OEM but they last longer as there is more meat on the rotor ring.
Nope, NCCC rules have not changed much. You can run ss lines; air ducts; slotted, dimpled, and/or drilled rotors; and a bias spring in Group 2. Heck, running the GS calipers is enough to put you in Group 2, even if you had J55 to begin with.
