Aftermarket C5/C6 Wheel Widths?
Old 04-04-2011, 07:22 PM
dfinke23
Support Corvetteforum!
dfinke23's Avatar
Default Aftermarket C5/C6 Wheel Widths?
I know the C6Z guys are running 18x11/18x13 wheels. What are the most common widths run by C5's and base C6's, and what do you T1 guys run?
Old 04-04-2011, 07:26 PM
froggy47
froggy47's Avatar
Old 04-05-2011, 01:43 PM
dfinke23
dfinke23's Avatar
bump
Old 04-05-2011, 05:43 PM
SouthernSon
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes on 717 Posts
I am not sure how aftermarket and widths fit into the equation but if you are after clearance issues I can tell you that an OEM C5Z wheel will fit Wilwood SL6's but the 'aftermarket' motorsport won't without spacers. It is thicker and heavier. As far as good track setup, OEM C5Z 18" rears all the way around with 315's work very well.
Old 04-05-2011, 07:31 PM
froggy47
froggy47's Avatar
They rub the fender lip on the front of mine, lowered on stock bolts.
Old 04-05-2011, 11:56 PM
dfinke23
dfinke23's Avatar
What are the T1 guys running, and how wide are the C5Z rears?
To Aftermarket C5/C6 Wheel Widths?
Quick Reply: Aftermarket C5/C6 Wheel Widths?
