oil pressure
oil pressure
My 67 corvette has a new 540 that I usually drag race, but I am putting autocross slicks on it for an upcomming corvette meet. Will I have an oil pressure issue with the stickie rubber? It is a gen VI bowtie engine. thanks all
Most of the oil pressure problems were the result of the oil pan setup and lack of channels to keep the oil from slosching out. When I used to autocross my midyear, I had a 20lb sender in the block wired to a 1" round stop light-mounted on the steering column. As soon as the pressure dropped to 20 lb it would light up--and it was big enough to see regardless of bright sunlight, going straight, in a chicayne or in a turn.
Depends on your oil pan and pickup.... I don't know anything about C2s other than they sure look cool.
Usually it takes long high-speed sweepers to creat oil pressure issues. Most auto-x courses are shorter with lots of quick turns and changes in direction.
Thanks for the info..I ran into problems with my small block oiling, years ago and installed a light to come on at 30 lbs of pressure via a hobbs switch. Works well, but was just curious if anyone has had problems with big block oiling while autocrossing...it is impossible to see your gauges while doing the cone dance...unless, of course you don.t mind sliding off course.
the pan I have now is basically just a drag pan with minimal baffling. Think I will install my accusump just to me safe. Though not much space for it.
