Help with Phoenix Tow Hook Install - front / z06-gs
Old 04-08-2011, 03:25 PM
Rob Willis
Rob Willis's Avatar
Default Help with Phoenix Tow Hook Install - front / z06-gs
Got the fascia/nose off for a ZR1 splitter install.
Took the styrofoam off.
However, is this something new they've put inside the front frame rail where you have to put the nut to mount the tow hook base or is this removeable? Never heard about it when reading about installs.
Gotta get in there to put the nuts on the bolts somehow!?
THanks!
Old 04-08-2011, 04:29 PM
KY-Traveler
Support Corvetteforum!
KY-Traveler's Avatar
CI 7-8 Veteran
St. Jude Donor '07-'08-'09
The corragated piece is spot welded in. You'll have to knock it out.
Old 04-08-2011, 06:01 PM
Charley Hoyt
Charley Hoyt's Avatar
I found that same metal piece in my '08 when I added the front tow hook. I called Jeff at Phoenix and he told me to just prey /knock it out....which I did. It comes out pretty easily. If I remember correctly...there may be two that need to be removed.
Old 04-08-2011, 06:35 PM
B y r o n
B y r o n's Avatar
Instead of knocking out the stiffener how about putting in a blind nut. You would probably have to drill out the hole but after that it's simply insert and set with the tool.
Just a thought.
Old 04-08-2011, 08:04 PM
VatorMan
VatorMan's Avatar
CI 6-7-8 Veteran
St. Jude's Donor '06-'10-'11, '15
Drill hole in front big enough to drop the nut through and hold with a wrench. My buddy and I did it and he actually put his to use a few weeks ago. Worked like a champ.
Old 04-08-2011, 10:27 PM
Rob Willis
Rob Willis's Avatar
Thanks for the help guys, I just knocked the spot welds out and then bent the piece back down after installing. It's sandwiched in their vertically, so I don't think the spot weld is THAT important.
Old 04-11-2011, 05:10 AM
jfaphoenix32
Supporting Vendor
jfaphoenix32's Avatar
we will add that to the instructions
To Help with Phoenix Tow Hook Install - front / z06-gs
Quick Reply: Help with Phoenix Tow Hook Install - front / z06-gs
