did you unload the spring so that the adjusters can turn freely.......They can seem unbelievably tight if they are loaded against the control arm.
Unfortunately I've done it correctly. I had a brain-child to weld a nut on the top. If that doesn't work, I'm screwed. (I stripped the tops in haste / desperation.)
I'm really pissed, 'cuz had I taken a wire brush to the threads when it got difficult, this probably wouldn't have happened.
Which still begs the question: which spring... It's a DD, so ride degredation is somewhat a consideration, too.
I had the exact same problem recently. Tried to weld a nut to it, double nut it and cussed at it a lot - nothing worked.
I had to pull the spring from the car and clamp it in a vise to break it free. They were frozen badly from rust, but I was able to get them out.
