Which rotors?
Old 04-10-2011, 05:45 PM
Bonefishmak
Bonefishmak's Avatar
Default Which rotors?
I'm about to buy rotors so, wanted to know what you have, how you like them and their performance. I'll be doing mainly street driving. I want to do a slotted and/or cross drilled set up. I have a narrow body c6 with base suspension.
I've seen two or three vendor threads on the site with rotors for sale so, hoping I can get in on one of these deals. Trying to stay under $400.00
Anyone have the Brakemotive? Or TPS? Or ones from Doc-Z? Thoughts?
Thanks!
Old 04-10-2011, 06:41 PM
Rag Top
Rag Top's Avatar
Drilled are bling for the street, but not much for the track (imho). You usually get stress cracks off each of the holes when you really get on the binders-like at the track. Not a problem on the street, but at the track it could grow a big problem.
Old 04-10-2011, 10:18 PM
waddisme
Support Corvetteforum!
waddisme's Avatar
If you are not doing track, then, go for the d/s as they look much better. I think in the For Sale section there is a special on d/s for like $180. Track days, stock blank ones are the best. HTH.
To Which rotors?
Quick Reply: Which rotors?
