removing hubs???
removing hubs???
I am replacing my hubs with the SKF hubs. Having a hard time with the third torx screw on the hub. Is the only way to pop the knuckle out?
Go to Autozone, check out their pitman puller, use that to put some load on the ball joint stud, then hit it with a hammer. That's worked every time for me.
HTH, and have a good one,
Mike
Mike
Remove the nut from the lower ball joint.
Put a floor jack under rim of the hub. Jack it up a bit so that some load is on the jack pad. Hit the lower control arm where the ball joint bolt goes through it with a 3# hammer.
It will pop loose very easily.
