My LS6 is running strong, but a little funny....
I have a new crate engine in my T1 car. It is running strong in the mid-range to top-end at 7100 RPM, but it is not quite right.
In mid RPM range, around 2500-4000 RPM and less than full throttle it runs kind of like a loaded up two stroke and then as I put my foot into the throttle near full or more and as it crest 4000 RPM the somewhat blubbering exhaust note clears up and she takes off... kinda' like a two stroke, but not as pronounced.
I did get the engine retuned as the crate engine went in two months ago. I don't recall this problem at my first two races at WSIR, but I did notice it my past two track days including this past Sunday at Buttonwillow. I have our biggest local double national race coming up in three weeks at BRP so I want to have this cleared up.
I plan to take the car to RPM Motorsports on Friday and have them refine the tune then. We kept it ever so slightly rich during the break-in period. I will have them look at it too.
It is not throwing any codes.
Any ideas?
Oli
Any ideas?
Oli
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,101 Likes
I get nervous when fuel trim does strange things in the 4k rpm range since melting numer 7 last year. My rpm demonstrated a hiccup in the 4000-4500 before letting go. Transition wasn't quite right.
Oli, I agree plug wires and plugs would be the first place to look and then do some logging with hp tuners.
Edit: just re-read varkwso's post and noticed you said it only runs bad when not at WOT, so maybe that's not my problem.
^ The front O2 sensors are not supposed to be crossed, the rears are. Some LT headers only use the front O2s but move the bungs farther back and people mistakenly cross them side to side.
The rear O2s just check that the cats are working so on my build I plugged the holes and deleted them with HPTuners... onle less thing to worry about when dropping the H-pipe.
If your car is tuned in Speed Density then it doesn't use the MAF or the O2s at all... just the MAP sensor at the back of the intake manifold.
Running speed density is unrelated to use of the front O2s, it only affects whether the MAF is used. Open vs. closed loop involves the O2 sensors. You can run speed density in either closed (during idle/partial throttle) or open loop.
You're right... been awhile since I messed w/ SD. My old cammed Z06 was tuned in SD to get the around town manners back.
You can always retune the MAF as well, to give you the benefits of the OEM hybrid MAF/SD system.
Anyway - Oli - as mentioned, you need a log file to figure out what is going on, with a wideband would be ideal. May be a PITA, but way easier than swapping in a new engine.
Oli, pick up an innovate LC-1, they're fairly cheap, and theres a hack where you put one of its outputs into the unused-on-the-c5 egr input on the PCM (pin 55 on the blue connector IIRC), that lets you log AFR via the obd2 port instead of a separate cable.
The LC-1 is kind of sketchy (reliability, accuracy). Power AFX seems to be the best bet for a budget wideband. But, if you don't have a HPTuners already, I'd bring it somewhere that knows LS engines, do a dyno pull and ask for the log file and see if they notice anything amiss.
