Question for those who have installed the ATI quick release steering wheel kit
Did you have to remove the SIR coil?
Does anything else have to be moved once the steering wheel and airbag are removed?
Regarding the torque value of the spline nut, the GM service manual says 30ft lbs, the grant instructions included with the kit says 5ft lbs with locktite. I am assuming I will go with the Grant torque value but wanted to see what you guys did.
