Kill switch... which one?
Old 04-16-2011, 02:50 PM
travisnd
travisnd's Avatar
Default Kill switch... which one?
I want one with a red handle.... is any particular one better than another?
Old 04-16-2011, 08:08 PM
triple_s1x
triple_s1x's Avatar
In my old race car I used the flaming river battery / alternator cut off switch. It wasn't a handle it was more a **** that you hit to kill power, and twist to power back up.
Old 04-17-2011, 01:59 AM
sperkins
sperkins's Avatar
I used the Longacre switch. Got it from discovery Parts.
Old 04-17-2011, 09:17 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Don't get this one, the "removable key" is a PITA:
Old 04-17-2011, 01:51 PM
Maynor29
Maynor29's Avatar
Brian,
You're going to need a 4-pole or 6-pole switch minimum like the Sytec found here:
http://www.ioportracing.com/Merchant...Category_Code=
I just installed that one a few weeks ago to kill the battery and alternator when the switch is disconnected. The initial two pole version installed did nothing to stop the alternator and the engine kept running on.
John
E36 LS2
Old 04-17-2011, 01:52 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Originally Posted by Maynor29
Brian,
2 pole will work if wired correctly.
Old 04-17-2011, 01:56 PM
Maynor29
Maynor29's Avatar
Jason,
Could be. We just couldn't figure out how when mine was wired up. Got a wiring diagram to share?
John
Old 04-17-2011, 05:11 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
http://forums.corvetteforum.com/auto...lp-needed.html
Tim's the EE of the group.
Old 04-17-2011, 05:38 PM
sperkins
sperkins's Avatar
Jason beat me to it.
Originally Posted by Timz06
There are a lot of people doing extra work out there, so here is an easier way to do this. I guess having a EE degree does have it's benefits after all.
The tricky part about this is that the battery cable positive terminal has two connections. One wire goes to the alternator, and the other to the distribution box. If you simply pull the positive cable off of the battery, the car will continue to run, as the alternator is supplying power to the distribution panel, which feeds the vehicle electrical system.
What is needed is to remove the power from the distribution panel. If this is done, it doesn't matter what the alternator is doing, everything is dead.
All you need to do is cut the cable between the battery and the distribution panel, and put your switch in series. Here are some pictures to illustrate.
Old 04-17-2011, 07:48 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
yes, Wal-Mart has them.....
Old 04-17-2011, 10:08 PM
travisnd
travisnd's Avatar
Yeah I've seen Tim's thread on which wire to tap into. John has a LSX in a Bimmer so his may be different.
Seems most all of them I'm seeing have the removable key.
Old 04-17-2011, 11:15 PM
davidfarmer
just safety-wire it to the dash.........
btw the wiring is simple. Easiest way is to disconnect the alternator wire AT the alternator, then run a new wire directly from the alternator to the "hot" side of your switch. I prefer to run a new line instead of cutting up the OEM wiring.
Old 04-18-2011, 06:11 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
It's a switch, how complicated/expensive does it have to be?
To Kill switch... which one?
Quick Reply: Kill switch... which one?
