Ti Speed Brake insulators w/ Hawk Padlets
Old 04-17-2011, 04:04 AM
jlutherva
jlutherva's Avatar
Default Ti Speed Brake insulators w/ Hawk Padlets
Bad combination The Hawk padlets (I don't know about the full length pads) have rivet heads on the backing plate. These rivet heads, working with the flat Ti insulator, push the pistons back into the caliper and result in a long petal. The first trip out of the garage was exciting.
I ended up grinding the rivet heads down. Speed Brake should include a caution to not use this product with and pads/padlets that are not flat.
Jim
Old 04-17-2011, 07:18 AM
PeOR
PeOR's Avatar
Default Cut
I cut mine so that the rivets came free. Works good.
PeO.
Quick Reply: Ti Speed Brake insulators w/ Hawk Padlets
