Doing first 2 day at VIR - what else will I need?
Old 04-19-2011, 09:24 AM
waddisme
Support Corvetteforum!
waddisme's Avatar
Default Doing first 2 day at VIR - what else will I need?
After 4 years of tracking, this weekend will be my first 2 day event! Before I got my race seats, one day pretty much wore me out. Just curious if there is anything different or additional I should bring? I trailer so I will have extra vehicle. I am thinking a car cover, 2 qts of oil, extra hub and wheel studs. Anything else? Do you guys stay overnight at track? Any problems leaving car/trlr/equipment overnite? My R888s are at the wear indicators but I think I can get 2 days from them. I have my street BFG KDs for back up. Actually here is my checklist:
Stuff To Bring (Highly Recommended):
• HELMETS and Gloves
• Paperwork (completed)
• Required clothing (long sleeved shirt and cotton long pants)
• Listing of Computer Codes
• Tire pressure gage
• Tire air compressor w/fix-a-flat
• Engine oil (1-2 quarts)
• 1 container of brake fluid
• Brake bleeding equipment (tube/bottle, etc.)
• Duct tape
• Fire extinguisher
• WD-40
• Paper towels / rags / wipes
• Cotton towel for yourself
• Torque wrench w/ socket
• Brake pads repl tools – 16mm wrench, 21mm socket(bracket), 15mm(pads)
• Other tools (sockets, wrenches, pliers, screwdrivers, etc...)
• Contact paper w/scissors
• Windshield cleaner
Other Stuff To Bring:
• Spare parts.
o Serpentine belt
o Brake pads
o Rotors (front & rear)
o Caliper bolts and caliper bracket bolts and caliper pins
o Wheel studs and lug nuts
o Clamp kit
o Spare Wheels/extra set of tires
o Hoses
• Jack
• Jack stands
• Impact wrench w/breaker bars
• Gloves – Mechanix
• Funnel for oil
• Tie wraps
• Grease
• Ice chest (Drinks, energy bars, snacks)
• Sunglasses
• Sun screen
• Camera
• Extra tapes.
• Power Converter
• Flashlight
• Power Station
• Gas Tank
• Folding chair
• Tent
• Ground tarp
Anything else?
Old 04-19-2011, 10:13 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Water. I freeze a case of water then just throw it in the cooler. It keeps my beer cold and I always have a cold bottle of water.
Old 04-19-2011, 10:24 AM
Short-Throw
Short-Throw's Avatar
An extra hub is a good idea, but make sure you have a front and a rear.
Old 04-19-2011, 10:49 AM
Falcon
Falcon's Avatar
Originally Posted by Jason
It keeps my beer cold ...
Beer? You take beer to the track?
Old 04-19-2011, 11:03 AM
VTME13
VTME13's Avatar
You'll need an 18mm wrench for the front pads, too.
Old 04-19-2011, 01:37 PM
waddisme
waddisme's Avatar
I only have one, but I thought the front and rears were same?
You can have beer there. Frozen water is great idea for cooler.
Is that the size for back of the caliper pin? I use an adj for that but now I know.
Event packet says camping is allowed, so sleeping in truck is OK?
Old 04-19-2011, 01:48 PM
travisnd
travisnd's Avatar
I'd take more than 2 quarts of oil.... I literally take everything. I have 2 large plastic tubs I fill with all my spare parts and fluids and crap.
If you take spare hubs make sure you take the tools to swap them... I almost forgot my axle nut socket once.
VIR has wifi so if you have a laptop you'll have forum access and access to any code info etc. you need.
I sleep at the track often, VIR has great facilities. The only annoying thing is the super cold AM walk from the trailer to the bathroom/showers, but that shouldn't be an issue this time of year.
Old 04-19-2011, 03:10 PM
RaleighSS
RaleighSS's Avatar
you heading to the Trackdaze event?
Old 04-19-2011, 03:54 PM
travisnd
travisnd's Avatar
No... my car is going in for a cage on May 1st. Just finished doing all of the prep work. Should have it back on track for June @ Road Atlanta.
Old 04-19-2011, 07:20 PM
StKnoWhere
StKnoWhere's Avatar
You will have a blast at VIR.
I'm sure you know VIR is a fairly technical track, studying it before hand helps. Most every turn is variable radius/camber with elevation changes and several blind sections so it's worth time studying video before hand enough where you can visualize a lap.
Peter Krause description of a VIR FUll Hot Lap.
http://www.nac-srcc.com/TechNotes/VIR_Full_Lap.htm
Old 04-19-2011, 08:34 PM
racerbob4
racerbob4's Avatar
Tires?
Old 04-20-2011, 09:45 AM
waddisme
waddisme's Avatar
R888s are at wear marker and I have a new set of BFGs on my street wheels for back up. Tried to get some R6 scrubs but none available. Thanks for the Krause link. That is pretty detailed. Printed it out to take with me. Did not know about the wi-fi, so laptop definitely. Got fresh ATE in last night. Pads, rotors, seats, fire ext and greasing slide pins tonight.
Thanks!
To Doing first 2 day at VIR - what else will I need?
Quick Reply: Doing first 2 day at VIR - what else will I need?
