HELP! RAM Clutch "conversion" for C4
Old 04-21-2011, 09:14 AM
RacePro Engineering
RacePro Engineering's Avatar
Default HELP! RAM Clutch "conversion" for C4
Gentlemen,
We are investigating using the RAM Clutches "Conversion Kit" in our 1995 C4. (It changes the GM 1994 thru 1996 "stock" pull-to-disengage system, to a push-to-disengage system.)
After examining the RAM parts, including the questionable throw-out bearing, and the INTERNAL slave cylinder; we are wondering how relaible this package really is for the track.
QUESTIONS: From those of you using this FOR RACING - what have been your experiences and observations?
Are there other, better packages for these years (1994-1996) C4?
Are there light-flywheel, high-clamping force packages that bolt right in, without changing the direction of action of the clutch?
All learned opinions are appreciated!
Ed LoPresti
Old 04-21-2011, 06:51 PM
jwt1603
Support Corvetteforum!
jwt1603's Avatar
Originally Posted by RacePro Engineering
Gentlemen,
QUESTIONS: From those of you using this FOR RACING - what has been your experiences and observations?
Ed LoPresti
In our 1994 I'm over 500HP with a 383. I went with a Spec 4 clutch and aluminum flywheel. Auto-X only car, occasional HPDE, no street time at all. Two drivers and no problems after two hard seasons.
I will say that we're planning on removing the ZF because of weight. A Tremec is a lot lighter and easier to get parts for. Plus with AutoX and HPDE we have no need of a 6th gear. And then we can get rid of the stupid C-beam.
just my opinion of course.
Old 04-21-2011, 07:22 PM
Kubs
Kubs's Avatar
Received 1,731 Likes on 936 Posts
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Contact Matt Carlyle here on the forum MRC24X
He used a RAM clutch with the Mcleod hydraulic throw out bearing on his race car. He is a very very fast driver so I would say it worked out for him.
Old 04-21-2011, 08:10 PM
RacePro Engineering
Thanks, Joe,
We appreciate hearing about alternatives like this. We'll check out Spec 4.
Hi Mike,
Mc Leod is another of the options at which we are looking. They seem to offer a plug-and-play kit, with no change in directional activation necessary.
Ed
Old 04-21-2011, 09:13 PM
mrc24x
mrc24x's Avatar
I bought the Ram "conversion" kit in '07. The clutch is lightweight and really nice but I thought the Ram TOB was junk. I ended up buying the expensive Mcleod TOB that mounts in place of the input collar. It's pricey but a nice product.
I switched to a 5.5" QM clutch this year so my old setup is for sale.
Ram Conversion LW Al. flywheel/PP/Clutch + Mcleod Hyd. TOB + Clutch Master Cyl. and lines. $500 to your door. Everything works great.
The Ram Kit new is $1099 and the 1345 Mcleod Bearing is $446 fwiw.
I also have my ZF6 for sale for $900 but I have a few people interested in it at the moment. (I'll know more after the weekend)
Matt
Old 04-21-2011, 09:42 PM
RacePro Engineering
Matt,
This is great information, and thanks. In addition to the throw-out bearing, another of our concerns is the relocation of the slave cylinder to INSIDE the transmission housing (a perinneal point of failure), plus the weakening of the transmission case, itself, with the drilling of holes for alignment and adjustment.
With your system, were you able to retain the slave cylinder on the fire wall?
With the use of the McLeod parts, did you still find it necessary to bore through the transmission housing?
I value hearing about your experience with this.
Ed
Old 04-21-2011, 09:52 PM
mrc24x
mrc24x's Avatar
Matt,
Ed
Ed,
You keep the standard Clutch Master Cyl. that mounts to the firewall and the transmission doesn't need to be drilled out for the Mcleod TOB. Just remove the stock cover for the input shaft and mount the TOB in it's place.
Here's a pic:
PLRX (09-29-2018)
Old 04-28-2011, 10:17 PM
dave_85
dave_85's Avatar
PM sent
Old 09-05-2018, 07:33 PM
SnorT91Man
SnorT91Man's Avatar
Default Question
[QUOTE=mrc24x;1577408777]I bought the Ram "conversion" kit in '07. The clutch is lightweight and really nice but I thought the Ram TOB was junk. I ended up buying the expensive Mcleod TOB that mounts in place of the input collar. It's pricey but a nice product.
:Is is Ram setup still available? I would be very interested. If it is, please tell me how I can reach you.
Thanks!
To HELP! RAM Clutch "conversion" for C4
Quick Reply: HELP! RAM Clutch "conversion" for C4
