Source for wheel spacers and studs?
Old 04-24-2011, 08:12 PM
UstaB-GS549
UstaB-GS549's Avatar
Default Source for wheel spacers and studs?
Looks like I'm going to need wheel spacers to clear my new AP Hardbar calipers with my OEM Grand Sport 17x9.5 front wheels. My street wheels, (OEM C5 Z06 front) has about 1/4" spoke to caliper clearance.
Sources for spacers and longer studs?
What about hub centric. Right now the wheels seem to pilot on the hub. What happens with a spacer?
Old 04-24-2011, 08:16 PM
Gman57
Gman57's Avatar
Check with Randy @ DRM
Old 04-24-2011, 08:40 PM
Painrace
Support Corvetteforum!
Painrace's Avatar
Jim
Old 04-24-2011, 09:28 PM
AtomicZ
AtomicZ's Avatar
Agreed. Randy @ DRM is our man.
Old 04-24-2011, 09:45 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
DRM has nice ones properly made.
Old 04-24-2011, 10:31 PM
davidfarmer
davidfarmer's Avatar
http://www.southwestspeed.com/?sec=v...sssub=Aluminum
these are really good, can be used on different bolt circles. I just bought a set (3/8") for a customer and they are great, especially for the price....$14
I used ARP studs 100-770 from either Summit or Jegs. Very cheap.
Anything over about 1/4" will lose the hub-centering, but your are looking at $250 for a set of DRM's spacers with the lip machined in. I like the idea of having hubcentric, but it just doesn't make "cents" to me to spend that kind of money on spacers.
Old 04-25-2011, 08:41 AM
Aardwolf
Aardwolf's Avatar
I have some of those, Summit has them for slightly more cost. Also ARP-100-7708 $12.66 1/2 longer studs. SUM-7540021 $2.95 lugs.
Old 04-25-2011, 08:58 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
FYI:
S10 wheel spacers are a lot cheaper than Corvette wheel spacers.
Old 04-25-2011, 06:44 PM
UstaB-GS549
I think I would need a 5/8" spacer to clear caliper with my GS 17x9.5 wheels. As much as I hate to part with them, I think it would be smarter to sell my wheels and buy another set that clears.
FWIW:
17x9.5 OEM Z06 front spoke to caliper clearance is about 1/4"
18x10.5 OEM Z06 clears by about 1/8"
17x9.5 OEM GS front wheel needs a spacer
17x11 OEM GS rear wheel has about 1/2" clearance
LG Wilwood supposedly clears the GS wheels, but I going to assume that they are referring to the 11" rears.
Old 04-25-2011, 07:00 PM
John Shiels
FWIW:
Larger spacers are fine if properly made. I have run .750" & .850 for thousands of miles. GS front rims will not clear SL-6 WW
Old 04-25-2011, 10:27 PM
UstaB-GS549
Did your spacers have pilot for wheel like DRM 5/8"?
Old 04-25-2011, 10:56 PM
ScaryFast
ScaryFast's Avatar
The hub ring is there for locating. The studs hold the wheel in place and take all the load. Spacers are not ideal, but they are safe. However, you must run longer, hardened ARP studs, which it seems you're already planning. Due to moving the wheel farther from the bearing they add load to the hub, but my fronts were never the issue, it's our rears that suck.
I've run spacers for 10 years to clear my 9.5" GS wheels. I think they are 3/4" thick.
Speaking of which, need some more wheels? I just upgraded to 18's
Old 04-26-2011, 05:42 AM
John Shiels
yes I have some from DRM and some from CCW &ARP studs,.
Old 04-26-2011, 06:58 AM
UstaB-GS549
Yes... if they are pair of super cheap OEM C5 Z06 17x9.5
What I spent on calipers is a touchy subject here... and it isn't quite warm enough to sleep in garage yet.
To Source for wheel spacers and studs?
Quick Reply: Source for wheel spacers and studs?
