How do i seal a CCW wheel? IE: What do you use for sealant?
Changed out a lip and need to re-seal the wheel. What should I use?
Clear 3M window/door caulk. I believe it's item #5000 on the tube/bottles. If you call CCW they'll verify. They also have some good how-to videos on their website.
I've done it a few times... it's not too hard, just a bit time consuming to screw all those nuts/bolts together.
I've done this several times and the stuff that CCW recommends works very well. It's GE Premium Waterproof Silicone in clear. Stock number GE5000 which you can get at ACE Hardware and probably a lot of other places too. The CCW website has a video on resealling a wheel if you're interested.
Received 1,754 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I used what others said.
Looks like this:
Just make sure it is the clear and not the black or white.
Looks like this:
naw, there has to be a better answer for the webbing. I'm not about to scrub every nook and cranny. I was thinking tumbling it in a sand tumbler or media blasting it, and using a 4" grinder with metal polish and a cloth pad for the flat faces.
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
Scotch brite and a good solvent is what I used successfully. In order to speed up the process of tightening the many bolts, I used a motorcycle rear wheel cradle roller. Any roller system will help, even those used by the linoleum/rug dealers. You need to plan everything before squeezing on the sealant. Quick assembly is really important.
