Adjustable end link question
Old 04-28-2011, 03:30 PM
M1Cruiser
M1Cruiser's Avatar
Default Adjustable end link question
New to Auto-X. How much of a difference do adjustable sway bar end links make in Auto-X?
Old 04-28-2011, 04:21 PM
dbratten
Support Corvetteforum!
dbratten's Avatar
None unless your car isn't level and it causes a preload on one corner. Also, if you corner weight your car they are usually necessary to adjust the swaybars to not preload a corner. Ideally, there is no load (the bars do not apply any force) when sitting static. When corner weighting you typically adjust a corner of the car to be higher (or lower) to transfer weight which then requires that the end link length be changed to accommodate that adjustment.
Old 04-28-2011, 04:35 PM
M1Cruiser
M1Cruiser's Avatar
Thanks Dan!
To Adjustable end link question
Quick Reply: Adjustable end link question
