275s and C5Z wheels - any reason not to use the 18s?
For running a square 275 setup - is there any reason (performance-wise) why I would want to use 17x9.5 wheels all around instead of the 18x10.5?
18s are a little heavier, but will give a wider contact patch (~.5").
Thanks.
Thanks.
The 17" wheel does not support the sidewall as well as the 18".
That being said, I've been wanting to try 18's on the front and 17's on the rear for some of the tracks we run. That extra sidewall may actually help on corner exit.
it really could be track dependent. (and tire specific, all 275's do not measure the same)
I had some 275/40/17s left over from another race car so when I first setup my car I did it on 17x9.5s all around. The car felt ok, but on the advice of the two bozos above I tried the 18" setup.
Car was 100% better on the 18s. I'm currently running a 255/35/18 on 4 rear Z06 wheels.
FWIW,
I ran these on my 97' square at VIR full track and they did very good:
OEM MAG 18 x 9.5 w/ new Hoosier R3S05 275/35/18 road race radial 4.532nds tread with std valve stems 42lbs ea.
Danny Popp thought they stuck pretty good..........
Received 1,754 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
This year I am going to try 275s on 18x9.5 wheels as well (C6 Z Fronts). Everyone seems to put the 275s on the 18x10.5 wheel so it nice to get some feedback on other options.
