What hoosier sizes?
What hoosier sizes?
I'm going to be doing Road Atlanta in July and I need to get some R6s on my C6Z06. For rims I'm using the stock fronts that are 18x9.5 and for the rears I have 18x12. Now do I run on the front the 275/35 or 285/30 and for the rear the 335s or 345s both in a 30 series.
Supporting Vendor
We have Continental slicks made by Hoosier in 285/645/18 fronts and 325/680/18 rears that would work perfect for your set up. PM or call me for details. $100.00 per tire plus shipping. One heat cycle, 80% plus rubber remaining.
Todd
414-350-6303
Todd
414-350-6303
A 295 will fit on a 9.5 rim? Also why not run the 345 in the rear?
Check out the hoosier tire specs.
http://hoosiertire.com/rrtire.htm
They give you the tire widths and diameters along with recommended wheel sizes. Yes a 295 will work on a 9.5" rim and the reason I recommend the 335 instead of the 345 is because of the tire diameter. I'm not sure about the C6Z stock tire sizes, but I don't think a 345 would work very well on my C5. I think it would rub pretty badly (my 335's are right on the edge and occasionally rub the fenders in hard bumps) and it would make my gearing slightly higher.
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,426 Likes
St. Jude Donor '08
I run 295/345 A6/R6 and have never had an issue on or off track. The front barely and I mean barely rub, but my car is lowered. The rears have never touched any part of the inner or outer fender panels.
Thanks Rich. Looks like I am calling tirerack tomorrow and spending absurd amounts of money on tires.
