Race Seat mounting question
When I look at the side mount brackets for race seats they look fairly simple considering how expensive they are. Is there any reason I couldn't just make a set from some 6061 T6 angle brackets (or stainless)? Or is there more complexity they there appears to be?
Thanks for the help,
Charley
Charley
When I look at the side mount brackets for race seats they look fairly simple considering how expensive they are. Is there any reason I couldn't just make a set from some 6061 T6 angle brackets? Or is there more complexity they there appears to be?
Charley
Charley
Charley
Charley
1/4" aluminum Angle from Ebay works just fine. FIA seat mounts are 5mm aluminum, so that's good enough for me. I need to find a picture of mine. You need to make sure it is tall enough to reach up high on most seats.
It does require some cutting, but if you don't have access to a sawsall, then you probably shouldn't be working on race cars!
I had the shop build a seat frame that goes between the frame and driveline tunnel and attaches to my roll cage. I don't trust our balsa wood floor to keep me where I should be in case of an accident.
Given my recent accident and the issues seat movement caused me....I would concur. The best mounting possible, in a Corvette tying to stronger elements would be the ONLY way I would do it in the future.....
FWIW the factory seat supports are metal bars taht are under the floor-pan. They are welded to the outer frame rail and the center trans tunnel. The seat studs go through them.
I cut out the top of my factory floor pan to lower my seat as much as possible and I have to say I couldn't make them flex. They're not as flimsy as some say on here. I know we go faster on track... much faster, but they are designed to hold a much heavier OEM seat. If anything I'd just re-inforce them from the underside.
EDIT - Plus the back of my seat will be tied into the cage. rmackintosh was your seat tied into the cage?
Yes, my seat back was tied to the cage...but it broke free due to the floor moving so much. The Camaro does not have much of a frame...unibody...and what I THOUGHT was a strong seat mount was compromised by massive floor movement.
Gary Hoffman (Hardbar) makes a great, light, adjustable seat mount that he can even customize for you. He made a slightly lighter version for me and even had it powdercoated white. It looks awesome and is ultra strong!!!
I'm just finishing up a set of mounts I made using an aluminum 45 degree gusset profile. The triangle shape is much stronger than an L shape. I'll post photos once I finish powdercoating them.
