Need recommendation for 2 way radio
Our chump team had a difficult time communicating last month at CMS. There was no problem listening and talking under yellow, but when going ***** out, there's no way to understand what the driver is saying. Not to mention it was less than convinient for the driver to push the button on the headpiece wire when wanting to talk.
Does anyone have a good solution to this problem? Is a throat mike the way to go...and just leave the radio voice activated? Whatever the solution is, the hope is that it won't break the bank. This cheap racing is turning out to be "not so cheap" .
I can't remember exactly which radio's we used, but I believe it was something like this http://www.midlandradio.com/On-the-Road.LVL/GXT1000VP4.
radios
We have been using Speedcom radios for years with great sucess. The driver uses the custom earplugs but the foam ears with speakers in them work just fine as well. We have 4 radios, 3 to use in a race and 1 spare. We also have 3 headsets. Speedcom sells a lot of radios to pro teams and as a result they get a lot of trade-ins which they sell for a lot less. We use one of those aluminum brief-case type boxes they sell at Home Depot for $20 to hold the radios and 2 chargers and the headsets. The drivers microphone is built into the bottom part of the helmet and you can do it yourself if you at all handy. All the headsets come with noise cancelling mics built into them and have comfortable foam earcovers for endurance races. I think the radios that we use are the D-16 but I know they have 16 channels. Speedcom can set up 4 or 5 channels for you but I have never had any interference with other teams regarding channels.
You can call Speedcom and talk to Toto Lassily at 386.760.7110 and ask him about his trade-ins for a good price or just order the stuff you need. Tell him Bob Hines said hi.
I run Motorolas and it's a good system, but to be honest, the best radios I've seen are the Kenwoods that my buddy Mike Scornavacchi has in his car. They communicate farther than my Motorolas and are clearer...smaller and lighter too.
If I had it to over again, I'd go with the Kenwoods.
We have had pretty good success with Sampson Racing products in the past. Not only do they work well, but they also sponsor and support grassroots racing. Something which we really appreciate!
http://www.sampsonracing.com
I shot you a PM earlier in the week but haven't heard back from you. What setup are you using in your helmet, and how are you doing PTT? It looks like the radios arent the issue, its everything else around it
But I'll gladly answer your question. Phoenix set up my system, and I use just the simple foam ear bud that plugs into the side piece attached to my helmet. Most of the time, the "Racing Communications" trailer is at the track and they'll set up your connectors, mouthpiece, etc in your helmet for a very reasonable price. My PTT is mounted to the steering wheel...not just strapped. Phoenix drilled a small hole thru the steering wheel and mounted the button on there. It looks better and is more stable.
I don't use an external antenna on this car, but I did on my C5. I'm not sure if the external antenna is any better than the stock radio antenna or not to be honest.
It's important to make sure that all your components are connectable and not just wired, so you can easily replace anything that wears out, screws up, or just gets outdated.
And unlike most drivers, I also have a scanner in my car too so I can listen to race control and the corner workers. I use the radio ear bud in my left ear and my scanner goes in my right. Some drivers don't like all that, but it does help keep me informed of what's going on a bit better/faster.
Hope this helps!
Here's a link to an article in Grassroots Motorsports Magazine about how to wire your helmet: Wiring the helmet!
I did mine just like this and it was easy.
You did!!?? I didn't get it and have nothing in my "PM box" so I'm not sure what happened there.
Hope this helps!
Hope this helps!
We aleady have a set of Midland radios that are great. Midland also has a PTT steering wheel mount. Unfortunately NONE of their headsets allow for enough volume to work in a racing environment.
I'd assume your Motorolla radio and setup is plently loud. If so, I'm game.
Heck, if you have pictures, that would be great too.
So exactly what PTT steering wheel mountable unit are you using? I'm leary about ordering anything when I cant see what connector is on the end of the harness. Same goes for the earphones and mic. Some say they work with this and that radio, but the connectors are completely wrong. So, any specifics are appreciated.
http://www.speedcomracing.com/index....mart&Itemid=13
If I were you though, I would buy a complete system...that way you know everything connects and is made for your components. Most of the new systems come with detachable universal components though so you can mix and match. And if you can't, the Speedcom guys who show up at the track make tons of adapters, etc that will mate up to each one.
If you'll come to a SCCA or NASA event when the radio guys are going to be there, all you need to do is bring the car to them, tell them what you're looking for and they'll install it then and there. Again, I'd go with the Kenwood radios. They are just awesome. But, if you want the Motorolas, I'll sell you mine at a decent price, and I'll go buy new Kenwoods.
