Another Oil Question - Valvoline's conventional 20w-50 VR1
Old 05-17-2011, 01:21 PM
Rob Willis
Rob Willis's Avatar
Default Another Oil Question - Valvoline's conventional 20w-50 VR1
Anyone care to comment on it?
http://www.valvoline.com/products/br...g-motor-oil/6#
Compared to Mobil1 15w50?
There are some rebates and good pricing going on right now with it.
Thanks.
Old 05-17-2011, 04:30 PM
MelWff
MelWff's Avatar
Received 1,817 Likes on 1,606 Posts
I use it but I have an older flat tappet type of cam which requires the higher additive concentrate that VR1 provides. Your engine on the other hand was designed for synthetics such as Mobil 1.
Old 05-17-2011, 08:09 PM
thehammer69
thehammer69's Avatar
I think that statement is a bit misleading. I'm willing to bet that the engines weren't specifically designed for synthetics...but synthetics are specified because of the high oil temps that result if the cars are road tracked.
Example...LS1's in 4th gen camaros were recommended to run a conventional 5w-30. While same LS1 in corvette had Mobil-1 factory fill.
Old 05-17-2011, 08:42 PM
Rob Willis
Rob Willis's Avatar
I change mine after every HPDE, so I don't think using this conventional will hurt anything.
Not to mention, FREE is nice.
Valvoline 20w-50 VR1 Racing Oil
Old 05-19-2011, 08:59 AM
waddisme
Support Corvetteforum!
waddisme's Avatar
I ran the Amsoil 20/50 all of last year. Oil temps would break 290+ even with oil cooler. Switched to 10/40 this year. Only one track day above 90*, but oil temps were ~270*. Will see as summer goes on. Just something to consider. Good luck with it.
Old 05-19-2011, 09:31 AM
Rob Willis
Rob Willis's Avatar
6qts free after rebate (and I have lots of addresses to send to - )
I'll give it a try and if it runs too hot, I'll switch back.
I switch oil (no matter what I run) after all HPDEs anyway. Cheap compared to $7k-10k
Old 05-19-2011, 09:09 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Changing the oil after every event does nothing except occupy your time. If something was coming apart you may catch it by seeing metal but that usually don't happen. I would not run it and engines are made differently than they were with regular oil engines back a ways.
When I bought my Miller welder generator they guy told me run the oil spec'd or you will be back in short order because it will blow up. It was 10W40 or 10W30 forgot which one. He had them all the time coming back.
If you pop your motor on dino oil you may have no warranty either.
To Another Oil Question - Valvoline's conventional 20w-50 VR1
Quick Reply: Another Oil Question - Valvoline's conventional 20w-50 VR1
