love when this happens :-/
Old 05-22-2011, 10:55 AM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
Default love when this happens :-/
Got a small tear in the boot...these were brand new to.....ugh
Old 05-22-2011, 01:45 PM
ptindall
ptindall's Avatar
BTDT.
Old 05-22-2011, 08:43 PM
chad156
chad156's Avatar
Always a good time cleaning up!
Old 05-23-2011, 10:26 AM
VGLNTE1
VGLNTE1's Avatar
These halfshafts were brand new....ugh
Old 05-23-2011, 12:10 PM
RX-Ben
RX-Ben's Avatar
Were these OEM or parts store?
Old 05-23-2011, 12:19 PM
MySR71
MySR71's Avatar
If you haven't already seen this, it might be of interest:
http://forums.corvetteforum.com/auto...-boots-te.html
Sounds like some have had trouble with non-OE boots.
Old 05-23-2011, 04:56 PM
SIK02SS
SIK02SS's Avatar
I'm guessing non-OEM, in which I'm not surprised. The T1 group has found the rubber joints are very different in construction and most likely material. OEM allows "X" amount of flex, where as non-OEM does not, and the result is what you see above. Sorry for your experience..
Old 05-23-2011, 06:07 PM
VGLNTE1
VGLNTE1's Avatar
How do you buy oem?
Old 05-24-2011, 11:58 AM
wmckeenster
wmckeenster's Avatar
FWIW, I did not find OEM boots help with this problem any better than aftermarket...in fact aftermarket boots I used lasted longer than OEM since they were much thicker.
I finally got sick of replacing them and had the axles cryo'd which reduced heat a great deal and have not had problems since.
Old 05-24-2011, 12:15 PM
SIK02SS
SIK02SS's Avatar
Originally Posted by VGLNTE1
How do you buy oem?
dealership or online gm parts ware house of your choosing
Old 05-24-2011, 12:17 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
How does this reduce heat in the boot?
Old 05-24-2011, 10:20 PM
errance
errance's Avatar
Please forgive my ignorance: what fluid is this?
Old 05-24-2011, 10:38 PM
RX-Ben
RX-Ben's Avatar
CV joint grease.
That is the color they use in NAPA axles...not sure about OEM!
To love when this happens :-/
Quick Reply: love when this happens :-/
