Soft clutch pedal question
At my last track event (Buttonwillow #14 CW) I experienced a very soft clutch pedal a few times...Specifically, it would only come half way up from the floor. Every time it did this I went to the Pits and let the car cool for a while. This is the first time that I have experienced this. I am not sure if it was caused from less then perfect (being generous here) heal / toe down shifting? Or if it was due to the fact that I had unlimited track time and maybe I didn't allow enough time to cool? What do you think?
Thanks for the help,
Charley
Charley
Charley
Charley
There are many threads on this common problem - search the "Autocrossing & Roadracing" section for anything with "clutch" in the title.
A good thread is this one: http://forums.corvetteforum.com/c6-z...-and-cure.html
No magic bullet, alas
And fwiw, the same dang thing happens on the GTO: pedal stuck to the floor at the end of a long straight. Installing heat shielding around the line didn't help. Sucking out and replacing the fluid after every session helped. Switching to an e36 helped more
