this a decent brake fluid?
Old 06-03-2011, 12:11 AM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
Default this a decent brake fluid?
http:/d/www.autozone.com/autozone/accessories/AGS-11-oz-DOT-5-brake-fluid/_/N-25ah?counter=9&itemIdentifier=540132_0_0 _
Old 06-03-2011, 03:06 AM
Sidney004
Sidney004's Avatar
No,its a silicone based DOT 5 and is not appropriate for use. The Valvoline DOT 3 & 4(480 F) or the Prestone DOT 4(500 F) that Autozone offers would be compatible.
Old 06-03-2011, 07:41 AM
VGLNTE1
VGLNTE1's Avatar
This?
http://m.oreillyauto.com/mt/www.orei...0449&ppt=C0069
Old 06-03-2011, 09:27 AM
mr.beachcomber
mr.beachcomber's Avatar
Default Define "Decent" Please
Originally Posted by VGLNTE1
It's a DOT 4 brake fluid and suitable for street use. I don't know what you mean by "decent" so I can't comment if this particular brake fluid meets your own requirements.
Here's a link explaining the differences between DOT 3, 4, 5, and 5. brake fluid standards.
Old 06-03-2011, 09:43 AM
travisnd
travisnd's Avatar
^ Good link... I always get confused betwen 3, 4 and 5.1. I do remember that 5 is silicone based and non-compatible with most braking systems. If I remember correctly a few motorcycles use DOT 5.
Old 06-03-2011, 06:18 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Finally, Castrol SRF is a racing brake fluid that is in a class by itself with patented chemistry and is, in my opinion, the best racing brake fluid on the market today.
from stoptech white papers
Old 06-04-2011, 10:59 AM
R Mackow
R Mackow's Avatar
Try ATE Blue.
Old 06-04-2011, 01:14 PM
vms4evr
vms4evr's Avatar
I hope so John. I just dumped the ATE out and am trying the SRF on Monday. It'll be a good enough test. Road Atlanta, 90 degree day, fresh brake pads, fresh bleed. We'll see if I am or am not boiling fluid as some suspect. For the cost it better do something...
Old 06-04-2011, 02:04 PM
Everett Ogilvie
Everett Ogilvie's Avatar
If most of the ALMS P1 and P2 cars can't boil it, and you do - something else needs help...
Old 06-04-2011, 03:45 PM
travisnd
travisnd's Avatar
I've been running ATE Superblue for years w/o issue. SRF is nice, but it's more than I care to spend on brake fluid.
Old 06-04-2011, 08:34 PM
John Shiels
They have bigger brakes per pound and better cooling to boot.
Old 06-04-2011, 11:03 PM
SIK02SS
SIK02SS's Avatar
I was consistently ~20* away from boiling SRF in my T1 car for a while..
Old 06-04-2011, 11:04 PM
MNCrystalRed2011
MNCrystalRed2011's Avatar
I have been using this DOT 5.1 fluid from NAPA:
https://www.napaonline.com/Catalog/C...006443459&An=0
Old 06-05-2011, 09:47 AM
Everett Ogilvie
For sure, and that really was my point - if a combination of extreme duty and component selection (hardware) is able to boil the best racing fluid available, then the components need to be looked into, don't you agree?
Old 06-05-2011, 10:04 AM
John Shiels
yes
Old 06-05-2011, 10:59 PM
dvandentop
dvandentop's Avatar
what was the stuff essex just starting carrying? looked like good stuff, srf for myself though
Old 06-06-2011, 12:23 AM
sperkins
sperkins's Avatar
Been running ATE for a while in TT with no issues, but had an obvious problem in March in the Thunder race. Going to try something different next time I hit the grid for a 45min race.
To this a decent brake fluid?
Old 06-06-2011, 08:58 AM
travisnd
travisnd's Avatar
10-4... I just can't see spending $80 or whatever it is on a bottle of fluid. But if that's what it takes so be it.
Old 06-06-2011, 11:21 PM
Gary2KC5
Gary2KC5's Avatar
SRF is simply the best BF on the planet
Originally Posted by R Mackow
Try ATE Blue.
ATE Blue/Amber is an excellent choice
You don't have to hope...it's the best
Oh come on...$80 for brakefluid when your spending thousands on track events?????
$80 on BF that lasts all season???
That said I've used SRF and it is awesome...it lasts the whole year (6 events) without worry...but ATE Blue/Amber or Motul performs very, very well. No issues with them either...and I'm hell on brakes.
So 2-3 flushes of ATE or just put in the SRF once, it's about the same.
I would say though that Motul, ATE, or SRF anything else and your rolling the dice...OK for an AutoX, not OK for Road America
Old 06-07-2011, 12:56 AM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
If you do the math, a 900 kg P1 car going 200 mph into T10 has virtually the same energy as a 3300 lb Z06 going 155 mph into T10.
Wonder how they'd stop after 1 hr with 12.80x1.25 front hardware and slide rail PBRs.
Quick Reply: this a decent brake fluid?
