Does the 2001 and up corvettes have a power steering fluid cooler standard?
Old 06-05-2011, 09:01 AM
mark b
mark b's Avatar
Default Does the 2001 and up corvettes have a power steering fluid cooler standard?
or is it just on the C5 Z06? I had to put one on my 2000 coupe. Just curious to know if they made it standard equipment later on
Old 06-05-2011, 09:43 AM
6SPEEDZ
6SPEEDZ's Avatar
No. I had to put one on a 2004. The C6's did not come with it standard either.
Old 06-05-2011, 11:00 AM
AU N EGL
AU N EGL's Avatar
C5 Z51s and Z06s did
Old 06-05-2011, 11:02 AM
2000BSME
2000BSME's Avatar
the tube and fin ones that they come with are junk anyway. It didn't do anything for me on track. I had to add a larger stacked plate cooler to notice a benefit (i.e. power steering fluid not boiling over and steering getting really heavy).
Old 06-05-2011, 08:13 PM
Snidley
Snidley's Avatar
I do think they help. Have a 2002 coupe that went through 2 pumps and steering racks in 3-4 hpde's. Been fine since.
Steve
Old 06-05-2011, 10:13 PM
2000BSME
2000BSME's Avatar
I went from no pump cooler to the stock one that z's came with, and then I added the stacked plate big boy out of necessity. If I'd have known what I know now, I would have completely skipped the stock pos cooler. That's a fact.
Old 06-06-2011, 10:58 AM
mark b
mark b's Avatar
wow i have the stock Z06 steering cooler and i havent had an issue, maybe because i run Nitto r2 tires and not true race slicks? reason Im asking is im looking at another vette to replace mine soon.. so any C5 with Z51 package has a steering cooler standard.. thanks
Old 06-06-2011, 01:12 PM
MJM
MJM's Avatar
I run a stock C5 FRC with Pirelli racing slicks and have had no problems with the power steering, even running at tracks out in the desert during the summer.
Matt
Old 06-06-2011, 01:29 PM
travisnd
travisnd's Avatar
In my experience the stock Z51/Z06 cooler is sufficient. I've never had a single PS issue over the years with mine.
Forum member Oyishdog's race car was made out of a '98 coupe so it didn't have the finned cooler at first and he'd boil it over often.
I had a student at Road Atlanta in March with a Magnusson supercharger which requires deletion of the PS cooler... even the little tube thing and he had PS fluid boiling over every session.
Old 06-06-2011, 01:32 PM
TS Motorsport
TS Motorsport's Avatar
What type of fluid were you running? If it wasn't a synthetic PS fluid then it was inadequate.
Old 06-06-2011, 01:38 PM
travisnd
travisnd's Avatar
Forgot to add that I've always run Redline full synthetic PS fluid
Old 06-06-2011, 03:10 PM
2000BSME
2000BSME's Avatar
^^^what you guys might be forgetting is the tracks at which you run at. I run at Barber, one of the most technical and low speed tracks that I know of, where the steering input is CONSTANT, Barber will stress a power steering system much worse than a Road Atlanta type track will, I'm sure you will agree on this point. Anyway, I've found the stock ps cooler to be insufficient at my hometown track, Barber motorsports park. Full synthetic fluid, slicks, and lap times of 1:45 had my system asking for help.
To Does the 2001 and up corvettes have a power steering fluid cooler standard?
Quick Reply: Does the 2001 and up corvettes have a power steering fluid cooler standard?
