DrySump Oil Change - Tip
Old 06-06-2011, 01:38 PM
Wasserott
Wasserott's Avatar
Default DrySump Oil Change - Tip
About as simple and cheap a solution as it gets. No draining...
Transfer pump $5.99
http://www.harborfreight.com/multi-u...ump-66418.html
24" stainless .5" OD tubing $11.98
http://www.onlinemetals.com/merchant...=312&top_cat=1
10 Minutes, no jacking, no mess.
Old 06-06-2011, 02:06 PM
travisnd
travisnd's Avatar
I use one of those on my Jetski. It's a Honda with a 4-stroke fuel injected 1300 cc 4-cylinder. Has a dry sump. Have to suck the oil from the oil fill and then a special port on the rear of the engine.
Old 06-06-2011, 02:24 PM
Falcon
Falcon's Avatar
You can also use that to fill your transmission and differential.
Old 06-06-2011, 03:17 PM
B y r o n
Support Corvetteforum!
B y r o n's Avatar
Do you suck the tank dry before or after you remove the oil filter?
Old 06-06-2011, 03:20 PM
Wasserott
Wasserott's Avatar
My filter sits remotely so I can do in either order.
Old 06-06-2011, 03:46 PM
GO_BLUE_VETTES
GO_BLUE_VETTES's Avatar
Doesn't you arm get tired pumping?
http://www.amazon.com/Mityvac-7300-P...7389424&sr=8-5
To DrySump Oil Change - Tip
Quick Reply: DrySump Oil Change - Tip
