clutch condition
Old 06-06-2011, 11:03 PM
fennerhillpro
fennerhillpro's Avatar
Default clutch condition
Is there a way to tell you clutch's condition? I are getting ready to do 2 back to back hpde and have inspected everything else how can I tell the condition of my clutch?
Old 06-07-2011, 09:41 AM
ipuig
ipuig's Avatar
St. Jude Donor '09
Drop the lower bell housing inspection cover.
Old 06-07-2011, 10:40 PM
trackboss
trackboss's Avatar
Drive on the open road, at highway speed, in 5th or 6th gear. Keep a steady speed and depress the clutch while still on the throttle. The rpms should immediately jump up. Then let go of clutch and watch tach. The rpms should immediatey fall. (Do not lift throttle during the entire exercise) If they don't you have clutch slip. This is not as good as a visual inspection and measurement, but it's free and stupid simple.
To clutch condition
Quick Reply: clutch condition
