Does changing to SS brake pistons make a big difference?
Old 06-07-2011, 11:48 AM
Charley Hoyt
Charley Hoyt's Avatar
Default Does changing to SS brake pistons make a big difference?
I have the standard Z51 brakes on my car and I am wondering if changing to SS brake pistons would be a big improvement? Or is it worth saving my money and eventually investing in a brake upgrade?
Old 06-07-2011, 11:52 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
decent improvement for the price from DRM
Old 06-07-2011, 12:09 PM
gkmccready
gkmccready's Avatar
Check out Randy@DRM's YouTube video and I think you'll convince yourself the pistons make a big difference...
Old 06-07-2011, 12:20 PM
Charley Hoyt
I watched that yesterday and it looks very impressive...Looking to get imput from people that have some track experince with them. It looks like an easy (but very messy) upgrade.
Old 06-07-2011, 01:01 PM
John Shiels
The thermal conductivity - k - for some typical materials: .
Polypropylene PP - 0.12 W/mK
Stainless steel - 21 W/mK
Aluminum - 221 W/mK
Old 06-07-2011, 08:52 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
We have been using Stainless Pistons for almost 35 years in stock calipers. They are hard to beat in terms of reliability and robustness at the track.
Customers that have had issues with boiling brake fluid, melting inner seals and scoring with the aluminum pistons have found the SS pistons to be a worth while investment!
The C6 Z51 uses the C5 pistons.
Randy
Old 06-07-2011, 09:59 PM
Charley Hoyt
Randy
Thanks Randy. It looks like it would be a good investment. I am trying to decide between upgrading my current brakes, upgrading to C6 Z06 brakes, or getting a big brake kit.
Old 06-08-2011, 12:51 AM
Hercules Rockefeller
Hercules Rockefeller's Avatar
Aluminum - 221 W/mK
6Al4V titanium - 6.7 W/mK. The ultimate brake piston material. Randy, any chance you will be whipping up some titanium pistons?
Old 06-08-2011, 03:06 PM
2000BSME
2000BSME's Avatar
Something about the law of diminishing returns comes to mind.
Old 06-08-2011, 03:14 PM
waddisme
Support Corvetteforum!
waddisme's Avatar
Maybe BPP will make you a package deal with their titanium lug nuts
Old 06-09-2011, 02:38 AM
rustyguns
rustyguns's Avatar
yes
Old 12-11-2011, 09:35 PM
YYZ06
YYZ06's Avatar
My understanding is that thermal conductivity goes both ways. Takes longer to heat up but once hot, longer to cool down. Could there there be an issue with damaging/melting the seals from the cumulative effect of running HPDE say, half hour on and half hour off?
I'm considering the DRM "Short Stop" kit (SS lines, SS pistons & rebuild kit, brake ducts) with Quantum spindle ducts for my new C5 Z06. I'd buy the ducting and SS brake lines anyway but I don't have any previous experience with SS caliper pistons.
Old 12-12-2011, 12:18 AM
rasrboy
rasrboy's Avatar
Before we could upgrade to bigger brakes in SCCA T1 class, we were allowed to change to SS on our stock calipers.
Huge difference and worth every penny.
Call Randy at DRM (Post above) thats where most of us bought ours and you cant beat the customer service.
Aaron
Old 12-12-2011, 07:23 AM
yakisoba
yakisoba's Avatar
BUT if you want to cook in your brake pistons, use the stock ones...
Old 12-12-2011, 09:41 AM
ssdeuce
ssdeuce's Avatar
I just bought these along with DRM's oil cooler. I plan on putting the caliper pistons in Friday.
Old 12-12-2011, 11:01 AM
johninar
johninar's Avatar
A word of warning.
I got the DRM pistons for my Z06 and they were everything that has been said about them.
BUT the "Mod Monster" took over 1 month later and "made" me buy 6 piston Wilwoods!
Just say'in.
Old 12-12-2011, 11:19 AM
redvetracr
redvetracr's Avatar
Randy
35 yrs ago, does that mean Doug used them in the C-3 cast iron caliper? and did they work better than the GM J-56 insulated pistons?
To Does changing to SS brake pistons make a big difference?
Old 12-12-2011, 11:28 AM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Yes he used them way back then. Yes they worked better then the J-56 stuff. Funny part about it all, after 20 years in the basement. The car still had a brake pedal. Of course they came apart to be rebuilt, they looked pretty damn good From my understanding everyone was running them back then.
Randy
Old 12-12-2011, 11:31 AM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
This is very true. The Stainless does take longer to cool down. We have been using them in HPDE type settings for a long time now. Not one problem with burning out seals earlier. I think having the piston is in the caliper-fluid and next to really hot things would even out the cool down.
I have video of the cool down also, but didn't want customers to sleep like high school economics vidoes
Randy
Old 12-12-2011, 12:28 PM
BEZ06
BEZ06's Avatar
Randy
Hey Randy
I checked your site and see the pistons, but where do I get new seals/gaskets???
At the track a week ago I had a pad pin bolt back out (stock C6 Z06 calipers). A padlet fell out and the piston behind that one padlet extended out and ground down on the rotor (gouged the rotor as well!).
I need a set of your pistons, but I also need new seals.
Like johninar said, the mod bug may "make" me get some good aftermarket calipers, but for the meanwhile I want to rebuild my OE ones.
TIA,
Bob
Quick Reply: Does changing to SS brake pistons make a big difference?
