Question on brake pad thickness for upcoming VIR event
Hello everyone,
I will be running in the yellow group at the upcoming VIR event and I am running on a set of Toyo R888 tires. I have Carbotech XP10 and XP8 brake pads. I have approximately 1/4'' of brake pad left in the front, do you think that will get me through the 2 day event at VIR? I have a new set of pads but would prefer to use the existing ones; however, I don't feel like changing them at the track either. Looking for input.
Hello everyone,
Hello everyone,
I will certainly bow to those with greater experience and I will ALWAYS agree with erring on the side of caution, but I just wonder if the level of experience and therefore speed is being considered. At the red/black group level of speed I agree wholeheartedly, no way they make it. At yellow? I ran yellow last year and my wife shared the car and ran green. We had a brand new set of XP8's on the car and didn't even come close to half wear. We're both much faster now and so I will be bringing extra pads and will change the moment they're looking like they need it, but I don't see the point in pulling out pads that are about 1/2 their starting thickness yet. Unless you absolutely don't want to deal with changing at the track of course. These aren't 20mm race pads.
Asking to get perspective, not arguing!
It makes no sense to pile up a car trying to save $300...use them at a track where the cost of brake fade isn't so significant.
They don't have to be 20mm race pads. The thickness of material is what helps determine heat/thermal capacity. If I'm running at VIR, I don't care if you are Intermediate or Advanced, I want the best braking I can have. Stock Corvette brakes don't have the greatest thermal capacity to begin with so I would put in the new pads and use up the "barely good enough" ones at some other track event
I mentioned the 20mm race pad only for a % of pad thickness reference, which is what I was using for my logic of "life left." I do also use the 1 piece pads in my C6Z06 stock brakes, not the padlet. That is supposed to help with heat dispersion as well from what I was told.
I don't use Carbotechs but I did run VIR last year in yellow and the previous year in blue. VIR is also not nearly that hard on brakes as are other tracks. That said, I think you can get through if you really have 1/4" min (taper included...the mininimum). It'd be wise though to have some sort of back up pads available--maybe another set in similar condition. Certainly you'll want to check after day1.
Thanks and another round of thanks to everyone else who answered. This place is a great resource because even if you embarrass yourself with a display of ignorance you can learn something!
If you get 3 days for the first 50% at a track you may only get 1 day for the last 50% at the same track.
Hello everyone,
Change the fronts before you come because you don't want to change at the track. Throw the old pads in the "crap I ran out of pad" box.
If you want to run them and change pads at the track, they may or may not last a day.
Bottom line is this: If you don't want to work on it (to change pads) during the weekend, swap out new pads and use the ones you have now as back up spares.
I ran a set of 10/8's that started at *just* a hair more pad than 1/4" in the front. The pads made it through 7 of 8, 30 min sessions at VIR - we missed the last session due to a bad off in another group.
One could say that I may have been coasting; I did lay back on the straights to keep oil/tranny temps down - hit 290ish oil temps in a few laps easy.
The other thing was I checked wear (pulled pad out and inspected) after almost EVERY session. Andy can attest to the fact that my car was in the air more than anyone else we were with that weekend. I'm also running cooling ducts and Titanium heat shields, which if you aren't you may want to think about.
I would say it also depends on the event format. If the event is 8/30min sessions, you won't make it. If it is 6/25min sessions, may be a different story, but you'll still have to pull a wheel off and check them.
Slightly different perspective here...............Swap the rears to the front. Then use the current fronts for the rear brakes. Take your new pads along for use after the 1st day......if necessary.
