Is it ok to run with C1232
I can't locate what is causing the issue. I'll have to spend more time. But in the mean time, i've pulled the 40amp ABS fuse so that ABS won't be doing anything funky.
Besides not having ABS and TC/AH, will there be any other issues?
THANKS!
CHuck
THANKS!
CHuck
It means your left front wheel speed sensor is open or short. Usually it is a bad connection. The sensor connector is on the back of the hub. It's a white or gray connector with 2 pins in it. If you disconnect and reconnect that usually fixes it but you should look inside to make sure there is no corrosion. If you follow the cable back across the control arm you will see the second connection on the engine cradle right below where the hard line and the flexible brake like join. This is the connector that is usually bad when people can't solve the problem messing with the one by the hub. If neither of those connections are bad and a wire isn't broken then it is the sensor itself in the hub but these rarely go bad unless the hub itself is shot.
Regardless it is the left front speed sensor circuit for sure.
Oh, and it doesn't cause any issues other than the ones you mentioned.
Thanks man, I've taken the connector off the wheel hub a dozen times and it seems to fix it for a few minutes then I'm right back where I started.
Good to know, won't ruin my track day. I just don't want a reduced power situation or funky application of brakes.
I'll look to swap harnesses right to left to isolate harness first.
Thanks,
CHuck
Thanks,
CHuck
Be aware of this issue...you may have to give folks an unusual amount of room. Or else just hope they don't do something so...
My issue was the wire connection at the hub...inadequate strain relief when this was re-routed from the brake cooling duct install.
As mentioned, be careful of flat spotting. Depending on the tire, you will only hear the squeal when it is way too late and you need to take your foot nearly off the pedal to cure the lock-up.
I ran about 6 events last year w/o abs, zero issues. This year put DTC70s up front and flatspotted 3 sets of front tires due to intermittent abs issues & the increased torque. ABS issue turned out to be a disintegrating wire from the speed sensor, coming from the hub cover.
Received 8,927 Likes
Pulling the fuse doesn't hurt but you don't really have to do it. That code shuts down the complete system until its fixed.
Bill
Bill
