Question for Canton Racing Accusump Users
Old 06-25-2011, 09:30 PM
GeorgeZNJ
Support Corvetteforum!
GeorgeZNJ's Avatar
St. Jude Donor '08-'09
Default Question for Canton Racing Accusump Users
I've had my unit for just under one year, its worked properly until about three weks ago when my electric pressure switch quit working. I bypass the switch and the valve works properly. Is the pressure switch a known consumable? (its the 25psi switch) Should I ditch the electric switch and just use a manual toggle switch? Thanks for your help.
Old 06-25-2011, 10:55 PM
Dirk Miller
Dirk Miller's Avatar
Pressure transducers certainly can go out.
Why not replace it? Drain the oil and just unscrew. Putting a new one in should be pretty easy. Maybe at that point you could make sure a fuse was originally installed. A pressure transducer could be more sensitive than the solenoid valve.
Old 06-26-2011, 06:27 AM
Rob's 73
Rob's 73's Avatar
Mine died within 3 months. I bypassed the pressure switch. I mounted the pressure switch inside the fender so replacing it would involve taking the fender off. Ideally the pressure switch should be mounted closer to the engine block.
Old 06-26-2011, 07:52 AM
GeorgeZNJ
GeorgeZNJ's Avatar
Mine is mounted in the same area as yours was, and yes I took the fender off to get to it. removing the fender wasn't so bad. So are you now using a manual toggle switch? Maybe I'm wrong, but doesn't the valve open unpon pressure falling? ie....car is running at 60-80 psi, pressure falls to 20psi and the switch senses the pressure decrease and closes the circuit sending power the the soleniod valve which activates and pushes its oil reserve into the engine. With a manual switch, I'm guessing you have to watch the oil pressure gauge and manually turn it on?
Old 06-26-2011, 07:56 AM
GeorgeZNJ
GeorgeZNJ's Avatar
I am replacing it, and yes, its very easy to do. The system uses a pressure switch with a predetermined set point to activate a soleniod valve. The solenoid valve doesn't sense anything, it only opens and closes according to what the pressure sensor tells it to do. Forgive my ignorance, but is a pressure transducer different than a pressure switch?
Old 06-28-2011, 01:37 PM
DOUG @ ECS
Premium Supporting Vendor
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,083 Likes on 655 Posts
Dry sump.
Old 06-28-2011, 07:36 PM
GeorgeZNJ
GeorgeZNJ's Avatar
Originally Posted by DOUG @ ECS
Dry sump.
A poromotional give away
To Question for Canton Racing Accusump Users
Quick Reply: Question for Canton Racing Accusump Users
