Where to find the pins which hold the pads in caliper
Old 06-25-2011, 11:04 PM
ScaryFast
ScaryFast's Avatar
Default Where to find the pins which hold the pads in caliper
I lost one of the pins that holds the pads in the caliper. It is a Brembo F40, the pins should be the same as a lot of the newer ones, though. It is the long pin that goes through the ears on the pads, and has a small cotter pin that holds it in place through a hole in one end.
I looked on their site and through several distributers but no one lists them and the customer service numbers I found were overseas. Wilwood shows lots but none looked quite right.
Anyone have a suggestion on where to get Brembo parts?
Thanks.
Old 06-25-2011, 11:07 PM
wallyman424
wallyman424's Avatar
Might as well just scrap the car.
does mcmaster carr have anything that'd work?
Old 06-25-2011, 11:22 PM
ScaryFast
ScaryFast's Avatar
My lord that place has everything. Lots of things that might work but certianly not the exact pin. I need to take some measurements and see exactly what I can use; some sort of long cotter pin is probably fine.
Thanks for the suggestion.
Old 06-25-2011, 11:25 PM
wallyman424
here you go
http://www.lpiracing.com/Brembo-Guid...0787p85055.htm
Old 06-25-2011, 11:37 PM
ScaryFast
ScaryFast's Avatar
You are my new hero. That's the one.
I found these guys, was going to call Monday as they seem to have everything. Looks like Stoptech parts will work for a lot of the Brembo calipers.
http://www.zeckhausen.com/Brembo/Consumables.htm
Regardless, now i don't have to.
I also learned that Amazon carries PFC and Hawk brake pads. Who knew?
Old 06-25-2011, 11:38 PM
ScaryFast
ScaryFast's Avatar
Out of curiosity, what did you use as your search string? "pin" and "caliper pin" weren't getting it for me.
Old 06-25-2011, 11:42 PM
wallyman424
first result for "brembo f40 pin", gives you a list of brake hardware at that lpiracing site.
my googling skills are untouchable
To Where to find the pins which hold the pads in caliper
Quick Reply: Where to find the pins which hold the pads in caliper
